Understanding the Force Constants of Springs in Combination
The discussion revolves around understanding how to calculate the force constants of springs when they are combined in different configurations, specifically in parallel and series arrangements. The original poster expresses confusion about combining springs and the role of force constants in these setups.
  • Conceptual clarification, Problem interpretation
  • Participants explore the relationships between force constants in parallel and series configurations, with some attempting to draw analogies to electrical resistance. Questions arise regarding the correct application of formulas and the role of mass in these calculations.
There are differing interpretations of how to approach the problem, with some participants providing guidance on the formulas for calculating net spring constants in both configurations. However, there is a lack of consensus on the correctness of certain responses, indicating an ongoing exploration of the topic.
Participants are navigating the complexities of combining springs and the implications of their configurations, with some expressing uncertainty about the foundational principles involved. The discussion reflects a mix of understanding and confusion regarding the application of concepts from physics.
emilykay
I don't understand how to calculate force constants of a combination of springs.
for example 2 spings parallel with the mass on one end lying on a table.
or 2 springs attached with mass at one end lying on a table.
i know that force constant = sum of forces/ extension
but just don't get how to combine springs!
Thanks!
EmilyKay
Hey Its Easy Man.just Assume The Springs As Resistance And Like We Calculate Net Resistances In Series And In Parallel Calculate The Net Spring Constant.ex-two Springs Of Spring Constant =k Conected In Series Are Equal Ti A Spring Of Constant 2k.the Masses Have Got No Role To Play.only Thing Is That U Have To Find How They Aye Joined In Seriesa Or Parallel.ok...
when in Parallel configurations:
since they are parallel, the extension must be the same.
k=sum (F) / x
hence [tex]k=(F_1+F_2)/x = k_1+k_2[/tex]
when in series configurations:
when in equilibrium, the tension in the two springs must be equal and the extension is the extension of the first spring + the extension of the second spring:
k=F/ (x1+x2)
take the inverse of both side:
[tex]\frac{1}{k}=\frac{x_1}{F}+\frac{x_2}{F}=\frac{1}{k_1}+\frac{1}{k_2}[/tex]
rohit88 response is incorrect. Please pay attention to the response given by tim_lou, which is the correct answer AND derivation.
Springs in series behave like resistors in parallel, which springs in parallel behave like resistors in series.
Zz.
  • · Replies 56 ·
  • · Replies 17 ·
  • · Replies 31 ·
