Thread Closed
Quadratic congruences with prime modulus
Share Thread Thread Tools
Oct16-06, 04:12 PM   #1
The question is:
Show that if p == 1 mod 4, then (a/p) = (-a/p).
(Note that == means congruent).
I know that if X^2==a mod p (p is a prime) is solvable then a is a quadratic residue of p.
For an example, I let p = 5 since 5==1 mod 4. Then, I let X = 2 and 4 just to check the equation. So:
2^2==-1 mod 5...........a=-1 is quadratic residue.
4^2==1 mod 5............a=1 is quadratic residue.
I know that the legendre symbol (a/p) is 1 if a is a quadratic residue mod p and -1 if a is a quadratic non-residue.
From my example, (-1/5)=1 and (1/5)=1, so I have found an example that shows (a/p) = (-a/p) but I'm having trouble proving it in general.
Thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct16-06, 04:39 PM   #2
Recognitions:
Homework Helper Homework Help
Do you know anything about (-1/p)? Have you seen Euler's criteron?
Oct16-06, 04:39 PM   #3
AKG
Recognitions:
p = 1 (mod 4) implies (-1/p) = 1.
Oct16-06, 04:50 PM   #4
Quote by shmoe
No shmoe, I don't know anything about (-1/p) and I just did some research on Euler's criterion:
if a is quadratic residue modulo p (i.e. there exists a number k such that k^2 ≡ a (mod p)), then
a^(p − 1)/2 ≡ 1 (mod p)
and if a is not a quadratic residue modulo p then
a^(p − 1)/2 ≡ −1 (mod p).
I'm not really seeing the connection of why this helps....thanks again
Oct16-06, 04:55 PM   #5
Recognitions:
If you are happy using Euler's criterion, how do
a^(p-1)/2 mod p
and
(-a)^(p-1)/2 mod p
compare when p=1 mod 4?
Also, by looking at (-1)^(p-1)/2 mod p, you can prove what AKG posted with Euler's.
If this is for a class, you should try to prove it using methods you've covered though. What do you know so far about the legendre symbol?
Oct16-06, 05:12 PM   #6
This is for a class but he didn't teach us ANYTHING about the legendre symbol. I'm guessing that 1 mod 4 implies (-1/p)=1 is critical but i still don't really understand.
I took shmoe's advice and found that, when p==1 mod 4
a^(p-1)/2 mod 5 equals (-a)^(p-1)/2 mod 5
Oct16-06, 05:26 PM   #7
Recognitions:
Quote by Ch1ronTL34
Oi, do you at least have a text you're expected to have access to?
Quote by Ch1ronTL34
5 is just one specific example of such a prime, but we can go with this a little bit. More important is what happens in the exponent, when p is 5, (p-1)/2=2. and you have:
a^(p-1)/2 =a^2 mod 5
and
(-a)^(p-1)/2 =(-a)^2=(-1)^2 * a^2 =a^2 mod 5
So you'd have
a^(p-1)/2 = (-a)^(p-1)/2 mod 5
and therefore (a/p)=(-a/p)
What was important here is the (-1)^(p-1)/2 part. It was 1 when p=5 above. What can you say about (-1)^(p-1)/2 when p=1 mod 4?
This is really asking about (-1/p). It comes in here because (-a/p)=(-1/p)*(a/p). More generally you'd have (a*b/p)=(a/p)*(b/p).
Oct16-06, 05:38 PM   #8
Yes shmoe, I do have a textbook...."Elementary Theory of Numbers" by William J. LeVeque. Unlike most mathbooks, this one is about 100 pages and very small....though its size has proven to be misleading...ANYWAYS:
When p==1 mod 4, (-1)^(p-1)/2 will be an even number because p will be odd (p=4d+1 for some d) and (p-1)/2 will be an even number...(-1)^even number is 1.
Oct16-06, 05:46 PM   #9
Recognitions:
LeVeque is a nice little book. It works in the ties with abstract algebra well.
Quote by Ch1ronTL34
Exactly. If p=3 mod 4, (p-1)/2 would have been odd, so you'd end up with -1, and you hopefully see (-1/p) is completely determined by p mod 4.
Back to your problem, you should now be able to show
(-a)^(p-1)/2 = a^(p-1)/2 mod p
when p=1 mod 4, by just pulling out the -1 from the left hand side like I did above. That's pretty much it.
Oct16-06, 05:54 PM   #10
Alright I think I get it now. Thanks so much for the help shmoe!
Thread Closed
Thread Tools
Similar Threads for: Quadratic congruences with prime modulus
Thread Forum Replies
quadratic equations and inequalities / applications of quadratic functions question Precalculus Mathematics Homework 3
Solving quadratic congruences Calculus & Beyond Homework 1
Solving a System of Congruences with A Changing Modulus Linear & Abstract Algebra 3
Solving polynomial congruences modulo a prime power Calculus & Beyond Homework 0
Youngs Modulus and Elastic Modulus Introductory Physics Homework 6
