Calculating Kinetic Energy for a Swinging Wrecking Ball
  • Thread starter Thread starter Zeitgeist
    Energy
The discussion focuses on calculating the kinetic energy of a wrecking ball with a mass of 315 kg, suspended from a 10.0 m cable at a 30.0º angle from the vertical. The potential energy (PE) of the wrecking ball is derived from its height relative to the lowest position, which converts entirely into kinetic energy (KE) as it swings back to the vertical. The formula for kinetic energy, EK = ½ mv², is confirmed as applicable in this scenario, emphasizing the principle of energy conservation where KE equals PE.
  • Understanding of gravitational potential energy calculations
  • Familiarity with kinetic energy formulas
  • Basic knowledge of trigonometry for angle calculations
  • Concept of energy conservation in physics
  • Calculate the potential energy of the wrecking ball at a 30.0º angle using PE = mgh
  • Explore the relationship between potential energy and kinetic energy in mechanical systems
  • Learn about energy conservation principles in physics
  • Investigate the effects of air resistance on swinging objects
Physics students, mechanical engineers, and anyone interested in understanding energy dynamics in swinging systems.
Zeitgeist
A wrecking ball, with mass of 315kg, hangs from a crane on 10.0m of cable. If the crane swings the wrecking ball so that the angle that the cable makes with the vertical is 30.0º, what is the potential energy of the ball in relation to its lowest positio? What will be the kinetic energy of the wrecking ball when it falls back to the vertical position? What will be the speed of the wrecking ball?
I have no problem finiding the potential energy, but I don't know how to calculate the kinetic energy. and i know EK = ½ mv², but i don't know how to use it here. What should I do?
In the system as you describe it, there is no loss of energy, so any potential energy is going to be converted completely into kinetic energy.
In other words, KE = PE!
Thanx a lot
  • · Replies 16 ·
  • · Replies 32 ·
