Solving a Car's Travel in a Flat Circle - Can You Help?
The problem involves a car traveling in a flat circle with a given radius, velocity, and acceleration. The original poster seeks to determine the radius based on the provided parameters, expressing uncertainty about the complexity of the question.
  • Participants discuss the application of acceleration formulas, specifically questioning the use of radial and tangential components. There is a focus on the correct interpretation of the acceleration direction and its components.
The discussion is active, with participants offering guidance on the correct approach to resolving the problem. There is an exploration of different interpretations regarding the components of acceleration and the relationship to the radius.
Some participants note potential confusion regarding the direction of the acceleration vector and its components, indicating that additional information or clarification may be necessary to fully understand the problem setup.
Xamfy19
The question is :
A car travel in a flat circle of radius R. At a certain instant the velocity of the car is 18 m/s west and the total acceleration of the car is 2 m/s2 at 46 degrees north of west. What is R?
I simply used a = v2/R and obtained 162 m. I suspected the question should be more complicated than I thought. Can anyone help. Thanks.
The formula u applied is for an so u have to take the component which is in the direction of radius or it shoul be radial component of acceleration. and velocity should be the tangential velocity
thanks, maybe more info needed
I took cos(46) of 2 m/s2 and used for the formula. It's not the correct answer. Do I need to figure out the linear speed? (apparently it is not 18 m/s)?
Thanks a lot.
The linear speed is 18 m/s, nothing wrong with that.
Draw a picture of what's happening and you will see that you took the component of the acceleration incorrectly.
should be sin instead of cos
I guess I've mistaken the direction 46 degrees north of west as west of north. I have just tried again and it worked. Thanks a lot.
