Proving the Law of Conservation of Energy Using a Pendulum
The discussion revolves around proving the law of conservation of energy using a pendulum. The original poster, Amy, presents various measurements and calculations related to the pendulum's energy at different positions, specifically focusing on potential and kinetic energy.
  • Amy attempts calculations for mechanical energy at two positions of the pendulum but questions the accuracy of her speed measurement. Participants raise concerns about unit conversions and the interpretation of given data. There is also discussion about the impact of friction and air resistance on energy loss.
The discussion is ongoing, with participants providing guidance on unit conversions and measurement considerations. Amy expresses uncertainty about her calculations and seeks clarification on the effects of string weight on the overall energy calculations.
Amy is working from provided measurements in a textbook and is tasked with calculations and a lab report without conducting the measurements herself. There is a mention of potential inaccuracies in the measurements and the importance of considering the center of gravity in calculations.
physicsgal
im suppose to do some calculations to prove whether or not the pendulum demonstrates the law of conservation of energy.
mass of pendulum = 240.3g = 0.2403 kg
diamter of pendulum bob = 3.50
initial height of pendulum bob = 48 cm = 0.48 m
length of pendulum string = 2.14 m
time interval of photogate light interruption = 11.8 m/s
so there's position 'A' and position 'B'
for 'A"
Emechanical = Ek + Eg
= (0.5)mv^2 + mgh
= 0 + (0.2403kg)(9.8)(0.48m)
= 1.13J
for 'B'
= (0.5)mv^2 + mgh
= (.5)(0.2403kg)(11.8^2) + 0
= 16.73J
i must be missing something (my calculations aint proving anything).. any help will be appreciated!
~Amy
Did you calculate the speed correctly? You list it as time but give units of speed, suggesting an error there. Furthermore, 12 m/s is pretty fast for a 2m long pendulum.
k, i think i see the mistake! it says "11.8 ms" and i thought they meant meters per second.
so 11ms = 0.011s?
so for B i'd go:
= (0.5)mv^2 + mgh
= (.5)(0.2403kg)((d/0.011)^2) + 0 = 1.13
im short on time but will figure this out tomorrow and post my results.
~Amy
just thought of something else. to find the velocity i just take the diameter of the bob divided by 11ms?
~Amy
so 11ms = 0.011s?
~Amy
Yes, but use the 11.8 ms as it was in your data. And yes, ms is milliseconds so 11.8 ms = .0118 s
i changed all the units to regular units (meters, kg, s, etc.) just to play thing safe.
for Ek (A)
i got: mgh
= (0.2403kg)(9.8 m/s^2)(0.48m)
= 1.13J
for Eg (B)
i got: 0.5mv^2
=(0.5)(0.2403kg)(2.966^2)
=1.057J
(to get the 2.966 velocity i took 0.035/0.01185s).
and then i just explain that mechanical energy becomes heat energy so the total mechanical energy gradually decreases. ?
~Amy
Yes, a certain amount of potential energy is lost to friction and air resistance, although 6% may be a little high. All measurements have uncertainty or inaccuracy, and that will also be a factor. One final question: when you measured the height of the pendulum, did you measure at the center of the weight at both positions A and B? It's important to measure the heights at the center of gravity.
i didnt do any of the measurements myself. I am taking an independent learning course, and the measurements are listed in the book, I am just suppose to do some qualculations and write a lab report explaining why and whether or the pendulum lab demonstrates the law of conservation of energy.
slight ot: does the weight of the pendulum string make a difference? like a light weight vs. a heavy one?
~Amy
Got it. Thanks!
~Amy
Good question. What do think?
shouldnt the string weight be added to the bob weight?
~Amy
Not exactly, because it isn't in the same place. Think about where its center of gravity (COG) is and where the bob's is. Any ideas on how you would add the string's mass to your problem?
  • · Replies 21 ·
