Calculating Air density as a function of height?
The calculation of air density as a function of height can be derived from the relationship between pressure and density. The relevant formula is p(h) = p₀e^{-gh/RT}, where p₀ represents sea level pressure, g is the acceleration due to gravity, R is the gas constant for dry air, and T is the temperature at height h. The pressure of the atmosphere decreases with height, and this decrease is directly related to the density of the air, which can be assumed to be proportional to the pressure for small height changes.
  • Understanding of the ideal gas law
  • Familiarity with basic thermodynamics concepts
  • Knowledge of atmospheric pressure and density relationships
  • Basic calculus for understanding changes in variables
  • Study the ideal gas law and its applications in atmospheric science
  • Learn about the barometric formula and its derivations
  • Explore the impact of temperature variations on air density
  • Investigate the role of altitude in meteorological phenomena
Students in atmospheric science, meteorologists, engineers working with aerodynamics, and anyone interested in understanding the physics of air density and pressure variations with height.
Noone1982
Is it possible to calculate the air density as a function of height? We know that density is given as,
[tex]p\; =\; \frac{M}{V}[/tex]
And that pressure is given as,
[tex]P\mbox{re}ssu\mbox{re}\; =\; pgh[/tex]
But I am failing to see the connection to combine the two to get air density as a function of height. Any insight?
It's a miracle that I remember this from my hydrology course (the most boring one): [tex]p(h) = p_{0}e^{-\frac{gh}{RT}}[/tex]. This is the expression for air pressure at a height h. [tex]p_{0}[/tex] is the air pressure at the sea level, T is the average temperature at the height h, and R is a gas constant for dry air.
The pressure of the atmosphere is the weight of the air above per unit area. If you move up slightly, the weight decreases by an amount that depends on the density and change in height. You can assume the density is proportional to the pressure. Your equation
[tex]P\mbox{re}ssu\mbox{re}\; =\; \rho gh[/tex]
is the change in pressure for a small change in height for which the density may be assumed constant.
