What is the tension in the cords of two hanging paint buckets?
  • Thread starter Thread starter chocolatecello
The problem involves two 3.0-kg paint buckets hanging from massless cords, where the tension in each cord must be determined while the buckets are at rest. The key conclusion is that since the buckets are in equilibrium, the tension (T) in the cords must equal the weight (W) of the buckets. The weight is calculated as W = mg = 3.0 kg * 9.8 m/s² = 29.4 N. Therefore, the tension in the cord supporting the lower bucket is 29.4 N, and the tension in the cord supporting the upper bucket is the sum of the weight of the lower bucket plus its own weight, resulting in a total tension of 58.8 N.
  • Understanding of Newton's laws of motion, specifically equilibrium conditions.
  • Basic knowledge of free-body diagrams and force analysis.
  • Familiarity with gravitational force calculations (W = mg).
  • Concept of tension in strings and cords in static systems.
  • Study the principles of static equilibrium in more complex systems, such as pulleys.
  • Learn about the applications of Newton's second law in dynamic scenarios.
  • Explore the concept of tension in multiple connected objects.
  • Review free-body diagram techniques for analyzing forces in various physical situations.
Students studying physics, particularly those focusing on mechanics and static equilibrium, as well as educators looking for clear examples of force analysis in simple systems.
chocolatecello
Allright, so I'm stuck on this problem:
"One 3.0-kg paint bucket is hanging by a massless cord from another 3.0-kg paint bucket, also hanging by a massless cord. a) If the buckets are at rest, what is the tension in each cord?"
Here's what I have so far:
I drew a free-body diagram with tension (T) pointing upwards and weight (W) pointing downwards on both buckets.
Then I tried to solve it like this:
Fnet=ma
sum of forces=W-T
W=mg
W=30(9.8)
W=294
T=ma
T=30a
so sum of F=294-30a
but now I have two variables and I'm not sure what to do. I think I'm missing something obvious here, so could somebody help point me in the right direction? Thanks :)
Since the bodies are at rest, then there is no movement, hence no acceleration, hence no need to use Newton's 2nd law.
Since the bodies are at rest, then they are in equlibrium with each other, which means that all forces acting cancel each other out (i.e. there is no net force).
Since the forces balance, then any upward force must equal the downwards force.
This is actually quite a simple problem and it is quite unnecessary to get so complicated in your calculations. In your free body diagram, you have to realize that your forces are in equilibrium. Perhaps it helps if you sort of have an idea where the net acceleration will be when drawing a free body diagram, which is not downwards as your equations suggest (though in this case it is actually non-existent). This will help you in more complicated problems like pulleys later on.
  • · Replies 21 ·
