Volume Integration: Find Solutions
  • Context: Undergrad
  • Thread starter Thread starter blumfeld0
    Integration Volume
This discussion focuses on setting up integrals for calculating volumes of solids of revolution. The first problem involves rotating the area defined by the curves y = 1/x³, y = 0, x = 3, and x = 4 about the line x = -3. The correct integral is π ∫₃⁴ [((1/x³) + 3)² - 9] dx. The second problem requires rotating the region bounded by y = x² and x = y² about the same line, with the integral needing adjustment for vertical washers, resulting in π ∫₀¹ [(3 - y)² - (3 - √y)²] dy.
  • Understanding of integral calculus and volume of solids of revolution
  • Familiarity with the washer method for calculating volumes
  • Knowledge of functions and their graphs, particularly y = 1/x³ and y = x²
  • Experience with changing variables in integrals, especially between x and y
  • Study the washer method for volume calculations in detail
  • Learn about the disk method and its applications in volume integration
  • Practice setting up integrals for solids of revolution with different curves
  • Explore the concept of symmetry in volume calculations for more complex shapes
Students and educators in calculus, mathematicians focusing on integral calculus, and anyone interested in mastering volume calculations of solids of revolution.
blumfeld0
hi guys. i just need help setting up the integral for the following two problems.
1. find the volume of the solid obtained by rotating the region by the given area about the specified lines.
y= 1/ x^3, y= 0, x=3, x=4 ABOUT x=-3
so i have integral from 3 to 4 of [(-3)^2 - (1/x^3)^2] dx
is that right?
2. find the volume of the solid obtained by rotating the region bounded by the given curves about specified line
y=x^2, x=y^2 about the line x=-3
so i have integral from 0 to 1 of [(3-x^2)^2 - (3-Sqrt(x))^2] dx
is that even close to right?
thank you
is that right?
No, but it's close. For each x, you are looking at the region between two circles. The inner circle has radius 3 and the outer circle has radius y+3. Also you have forgotten the [itex]\pi[/itex] in [itex]\pi r^2[/itex]! Your integral should be
[tex]\pi \int_3^4 [(\frac{1}{x^3}+3)^2- 9]dx[/tex]
Although, because of the symmetry, that will give you the correct answer, since you are rotating around the vertical line x= -3, your "washers" should be going vertically, so every "x" should be "y". Oh, and you forgot [itex]\pi[/itex] again!
thank you
  • · Replies 20 ·
  • · Replies 17 ·
