Solving a Plumb Bob Problem: Accelerating an Incline with a Diagram
The discussion revolves around a physics problem involving a plumb bob in a box car that is accelerating up an incline. The problem requires determining the acceleration of the box car based on the angles formed by the incline and the plumb bob.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationships between the angles and forces acting on the plumb bob, with attempts to derive equations for acceleration. There are suggestions to redefine variables and reconsider the components of acceleration in both x and y directions.
Several participants have provided insights and corrections to the original poster's approach, leading to a more refined understanding of the problem. There is an acknowledgment of mistakes and a shift towards a more accurate formulation of the equations involved.
Participants note the importance of considering both vertical and horizontal components of acceleration, as well as the need to redefine angles for clarity. The original poster expresses confusion over the complexity of the book's answer compared to their own initial solution.
Dorothy Weglend
I seem to be specializing in plumb bobs this week:rolleyes:
A box car has a freely hangling plumb bob (from the ceiling). It is accelerating up an incline. which makes an angle b with the horizontal. The plumb bob makes an angle c with the perpendicular to the ceiling. Find the acceleration of the box car.
This didn't seem that tough, but my solution is so different from the books that I thought I would ask about it. I hope someone has some time to look this over. I've attached a diagram for my work.
From the box car ceiling, I have two angles. One is just b, the same as the incline, which is the angle the bob would make with the perpendicular if there is no acceleration. The other is a, which is the angle caused by the acceleration. So a+b = c, the angle of the perpendicular to the ceiling.
Fy = T cos a - mg = 0
Fx = T cos a = ma
Solve these to get a = g tan a.
a = c - b, so the final solution is: a = g tan (c - b). Simple and nice. I wish it were right, too :frown:
The books answer is quite complicated:
a = g ((cos b)(tan c) - (sin b))
I tried simplifying this with some trig identities to get my expression, but it doesn't seem to be possible.
Thanks, as always, for any help.
Dorothy
Fx = T cos a = ma
I suggest you use a for acceleration and call the angle [itex]\alpha = c-b[/itex].
You are forgetting that there vertical component of acceleration so the vertical force is equal to mg + may:
[tex]F_y = T\cos\alpha = ma_y + mg[/tex]
[tex]F_x = T\sin\alpha = ma_x[/tex]
[tex]\frac{a_x}{g + a_y} = tan\alpha[/tex]
and [itex]a_x = a cos b; a_y = a sin b[/itex]
See if you can get that to work out.
AM
The box car (and the bob) is accelerating up the incline. This means that the bob is accelerating in both the x and y directions. So your equation
should be changed to
[tex]F_y = T \cos(a) - mg = ma_y[/tex]
you get the other component of the acceleration [itex]a_x[/itex] for considering the force components acting on the bob in the x direction. To get the acceleration along the incline you need to combine these two acceleration components.
The direction that it is not accelerating in in this case is perpendicular to the incline. So the problem "might" be solved easier if you choose the x-direction along the incline and the y-direction perpendicular to it.
Slight change to previous post.
Argh, what a dumb mistake! Thank you both very much.
Dorothy
Thanks again... What I ended up doing was this:
Sum Fy = T cos c - mg cos b = 0
Sum Fx = T sin c - mg sin b = ma
And solving these gets the same answer in the book... And it makes sense now, thanks to you guys.
Thanks so much!
Dorothy
  • · Replies 18 ·
