How to do integral for Cos(x^2)dx?
  • Context: Undergrad
  • Thread starter Thread starter jkh4
    Integral
The discussion revolves around the integral of cos(x²)dx, exploring various methods for evaluating it, including definite integrals, series expansions, and complex analysis techniques. Participants also discuss the nature of the integral and whether it can be expressed in terms of elementary functions.
  • One participant inquires about the integral of cos(x²)dx and expresses uncertainty about how to approach such problems.
  • Another participant suggests looking up the integral in a table, providing a specific result for the definite integral from 0 to infinity.
  • A different participant notes that the general anti-derivative of cos(x²) is not an elementary function, indicating it cannot be expressed using standard functions.
  • Some participants propose expanding cos(x²) into a series for approximation purposes.
  • One participant presents a proof involving complex analysis and the Gaussian integral to show the relationship between the integrals of cos(x²) and sin(x²).
  • Another participant questions a step in the proof, seeking clarification on the relationship between certain trigonometric values and the resulting expressions.
  • Several participants engage in a technical discussion about the use of contour integration and the application of Jordan's lemma in evaluating the integral.
  • Some participants argue about the rigor of the proof and whether complex analysis is necessary, with suggestions for alternative methods such as integration by parts or real analysis approaches.
Participants express differing views on the necessity of complex analysis for evaluating the integral and the rigor required in the proofs presented. There is no consensus on the best approach or the validity of certain steps in the proofs.
Participants reference specific mathematical techniques and theorems, such as contour integration and Jordan's lemma, without reaching a unified understanding of their application in this context. The discussion includes various assumptions and conditions that remain unresolved.
This discussion may be of interest to those studying advanced calculus, particularly in the context of integrals involving oscillatory functions and complex analysis.
jkh4
How to do integral for Cos(x^2)dx? Is there a chain rule for integral? Coz sometimes when I approach questions like that i just don't know how to approach...thanks!
you have to look it up in a table of integrals:
\int_{0}^{\infty} \cos (x^{2}) dx = \int_{0}^{\infty} \sin (x^{2}) dx = \frac{1}{2}\sqrt{\frac{\pi}{2}}
If you mean \int \cos^{2} x then you would change it to \int \frac{1+\cos 2x}{2}
And if you mean the general anti-derivative of cos(x2), it is not an "elementary" function. That is, it cannot be written in terms of functions you normally learn (polynomials, rational functions, radicals, exponentials, logarithms, trig functions.
or you can expand \cos (x^{2}) into a series and then integrate each term (and thus get an approximation).
by the way, how can you prove this:
Simple Solution
To prove:
Given:
e^{i \theta} = \cos (\theta) + i \sin (\theta) & the Gaussian Integral: \int_{-\infty}^{\infty} e^{-\alpha x^2} dx = \sqrt{\frac{\pi}{\alpha}}
Consider:
\int_{-\infty}^{\infty} e^{-i x^{2}} dx = \int_{-\infty}^{\infty}\cos (x^{2}) - i \sin (x^{2}) dx = \sqrt{\frac{\pi}{i}}
Now \sqrt{-i} = \sqrt{e^{-i \frac{\pi}{2}}} = e^{-i \frac{\pi}{4}} in the principal branch (-\pi < \theta \leq \pi)
Therefore:
\int_{0}^{\infty}\cos (x^{2}) dx - i \int_{0}^{\infty} \sin (x^{2}) dx = \frac{1}{2}\sqrt{\frac{\pi}{2}} - i\frac{1}{2}\sqrt{\frac{\pi}{2}} since the integrands are even functions.
QED
Hello there =)
I got it, its a brilliant way of proving it. But i think I am missing something ...
isnt it true that:
e^{-i\frac{\pi}{4}}=\cos{\frac{\pi}{4}}-i\sin{\frac{\pi}{4}} ?
and
\cos{\frac{\pi}{4}}=\sin{\frac{\pi}{4}}=\frac{\sqrt{2}}{2}
which ,I don't know how, got to be (according to you) :
\frac{1}{2\sqrt{2}}
...im really stuck here...can you help me?
like I said...im missing smth here...
...limits of integration...got it!
But the major task here is to show that your result holds for \alpha imaginary. This requires complex analysis.
It's not that major a task. It's pretty easy once you have the right contour. ;) For those interested,
\oint_C dz e^{iz^2}
where C is the contour with components C1 = the real axis from 0 to R, C2 = an arc of radius R subtending an angle of \pi/4, and C3 = a straight line from the end of C2 to the origin.
Since this contour encloses no poles, the contour integral is zero. Hence, parametrizing z = x on C1, z = Re^{i\theta} on C2 and z = xe^{i\pi/4} on C3,
0 = \int_0^R dx e^{ix^2} + iR\int_0^{\pi/4}d\theta e^{i\theta} e^{iR^2e^{i2\theta}} + \int_R^0 dx e^{i\pi/4} e^{ix^2e^{i\pi/2}},
which gives
\int_0^R dx e^{-x^2} e^{i\pi/4} = \int_0^R dx e^{ix^2} + iR\int_0^{\pi/4}d\theta e^{i\theta} e^{iR^2\cos(2\theta)}e^{-R^2\sin(2\theta)}
Now we take the limit as R \rightarrow \infty. The integral on C2 satisfies the inequality
\left|iR\int_0^{\pi/4}d\theta e^{i\theta} e^{iR^2\cos(2\theta)}e^{-R^2\sin(2\theta)}\right| \leq R\int_0^{\pi/4}d\theta e^{-R^2\sin(2\theta)}
Because \sin(2\theta) > 0 when 0 < 2\theta < \pi/4, the RHS of the inequality tends to zero as R grows large and hence doesn't contribute to the integral. We thus have
\int_0^\infty dx e^{-x^2} e^{i\pi/4} = \int_0^\infty dx e^{ix^2}.
Recognizing the Gaussian integral on the LHS and taking the complex conjugate to get the desired integral gives
\int_0^\infty dx e^{-ix^2} = \frac{\sqrt{\pi}}{2}e^{-i\pi/4} = \frac{1}{2}\sqrt{\frac{\pi}{i}}
as required for the above proof of the integral of cos(x^2) or sin(x^2).
Not easy enough, it would seem!
You need Jordan's lemma type argument - your current version doesn't hold water, I'm afraid.
<br /> \begin{aligned}<br /> R\int_{0}^{\pi/4} e^{-R^2\sin(2t)}dt&amp;&lt;R\int_{0}^{\pi/4} e^{-R^2 4x/\pi}dx \\<br /> &amp;&lt;-\frac{R\pi}{4R^2}e^{-R^2 4x/\pi}\biggr|_0^{\pi/4} \\<br /> &amp;&lt;-\frac{\pi}{4R}\left(e^{-R^2}-1\right)<br /> \end{aligned}<br />
Just draw a line segment from the origin to the point (pi/4,1) to get the line y=4x/pi and that is less than sin(2t) which is above it in the integration interval. That last expression then goes to zero as R goes to infinity.
Anthony said:
Not easy enough, it would seem!You need Jordan's lemma type argument - your current version doesn't hold water, I'm afraid.
If you insist on more rigor, it is easily supplied: on the integration contour the inequality
\sin(2\theta) \geq \frac{4\theta}{\pi}
holds. (Due to concavity of the sine function on this interval).
Hence,
R\int_0^{\pi/4}d\theta e^{-R^2\sin(2\theta)} \leq R\int_0^{\pi/4}d\theta e^{-4R^2\theta/\pi} = -\frac{4}{\pi R}\left(e^{-R^2} - 1\right)
which tends to zero as R tends to infinity.
Still pretty easy. ;) (Edit: And beaten to it, too!)
Of course, I can keep adding rigor and other steps I skipped:
so, because e^x is a monotonically increasing function, it follows that \exp(\sin(2\theta)) \geq \exp(\frac{4\theta}{\pi}); taking the reciprocal reverses the inequality, so we have \exp(-\sin(2\theta)) \leq \exp(-\frac{4\theta}{\pi}). By a theorem of calculus, if f(x) \leq g(x) on some interval, then
\int dx f(x) \leq \int dx g(x)
as long as the limits of integral are a subset of the interval on which the inequality holds. Thus,
R\int_0^{\pi/4}d\theta e^{-R^2\sin(2\theta)} \leq R\int_0^{\pi/4}d\theta e^{-4R^2\theta/\pi} = -\frac{4}{\pi R}\left(e^{-R^2} - 1\right).
Boy, that's a long proof! Maybe it isn't easy after all! No wonder mathematicians take forever to get anything done, always insisting on so much rigor! ;)
Don't know what Jordan's lemma is (will find out soon enough), but I'm pretty sure you can just integrate by parts to get the estimate for
R\int_0^{\pi/4}d\theta e^{-R^2\sin(2\theta)}.
Also you do not need complex analysis to evaluate the Fresnel integrals. You can use somewhat contrived arguments to compute the integrals via multivariable calculus. Since I'm more fond of real analysis at this point, I prefer real-analytic solutions.
Hence,
Excellent, well done!
You might not need complex analysis to evaluate integrals of this form, but it's the standard treatment. I'm sure there's actually a book containing lots of integrals that are usually done via complex analysis, but explicitly calculates them using real analysis. I don't really see the point (why rub sticks together if you have a lighter), but some are fond of such things.
How would your integration by parts estimate work?
An interesting note about multivariate calculus methods vs. complex calculus methods, to go on a slight tangent here, is that the Gaussian integral is evaluated by multivariate calculus instead of complex calculus because it's actually very hard to find a contour and integrand that you can actually use to evaluate the integral. I saw a contour integral for it once, and it was a somewhat contrived looking integrand. After some searching I found it (incidentally my Google search led to another thread on the forums which linked to the page with the document):
\oint dz \frac{e^{i\pi z^2}}{\sin(\pi z)}
Integrating around a parallelogram with vertices \pm \pi/2 \pm Re^{i\pi/4} and taking R to infinity gives the result.
(A note on the document linked to: it contains many derivations of the Gaussian integral, but they are not 'rigorous' derivations that would satisfy our mathematician friends in the audience - for instance, the standard double integral method is performed, but no care is taken in treating the limits of integration properly: they simply switch from \{x,y\} \in (-\infty,\infty)U(-\infty,\infty) to \{r,\theta\} \in [0,\infty)U[0,2\pi), which as far as a real analyst is concerned is too presumptuous, I believe ;) )
Hello,
Would it also hold true if the limits of integration are other than 0 to infinity that
\int_{ }^{ } \cos (x^{2}) dx = \int_{ }^{} \sin (x^{2}) dx ?
What about if x^{a} (x is raised to an arbitrary power like?
\int_{ }^{ } \cos (x^{3}) dx
Thank you for the help.
I ran into the same cos (x^2) in a problem... though not as complex. how do you solve this for zero? I need to find where the graph crosses the x-axis.
Cos (x^2) = 0...?
Crap, nevermind... been a while... ;)
can it be done without countor integration?
