Calculate Torque Needed to Spin an LP Turntable 648 Degrees
  • Thread starter Thread starter mikefitz
    Spin Turntable
The discussion revolves around calculating the torque required for an LP turntable to reach a specific angular velocity of 3.51 rad/s after spinning 1.8 revolutions (648 degrees) from rest. The turntable is modeled as a uniform disk with a given diameter and mass.
  • Participants explore the relationship between angular displacement, angular velocity, and torque, questioning how to apply rotational kinematics equations to find the required torque.
Some participants have begun to express the total rotation in radians and are seeking guidance on which equations to use for calculating torque. Others have pointed out the relevance of rotational kinematics and the connection to angular acceleration.
Participants mention specific equations provided by a teacher, indicating a potential gap in familiarity with the relationships between kinetic energy, moment of inertia, and torque. There is also a reference to a resource that outlines the analogs between linear and rotational motion equations.
mikefitz
An LP turntable must spin at 3.51 rad/s to play a record. How much torque must the motor deliver if the turntable is to reach its final angular speed in 1.8 revolutions, starting from rest? The turntable is a uniform disk of diameter 31 cm and mass 0.26 kg.
I know that 1.8rev is equal to 648 degrees. This means that the disc must spin 648 degrees to reach the required 3.51 rad/s for the record.
But I don't know how to begin to calculate the torque required to achieve that angular velocity. Where do I begin> Thanks
Begin by expressing everything in radians rather than degrees, and by reviewing the equations of rotational kinematics. They are directly analogous to liner kinematics.
so, total rotation (1.8 rev) is equal to 11.3097 rad. It must spin at 3.51 rad/s.
How do I use this information to calculate a torque? thanks again
Look at your rotational kinematics equations. Find one that relates a change in angular velocity to an angular displacement and a constant angular acceleration. Find another one that relates torque to angular acceleration.
There are other paths to the solution (ther usually are) but these two equations will be a fairly direct route.
equations my teacher has given me:
KErot = .5 I w^2
I = .5 m r^2
Torque = F r sin(theta)
I guess I am unsure which equation relates all these different elements together?
KErot = .5 I w^2
I = .5 m r^2
Look here and scroll down to the table showing the linear equations and their angular analogs.
http://online.cctt.org/physicslab/content/PhyAPC/lessonnotes/rotationalmotion/kinematics.asp
You should have seen all of these before. If you have not ssen them, you are seeing them now. Give particular attention to the last one. There is also a rotational analog of Newton's second law
F=ma <> Torque = I*alpha
See what you can do with these.
great, thanks for the help OlderDan - no I had not seen that last equation until I clicked your link.
  • · Replies 16 ·
10K
25K
32K
