What Are the Momentum and Energy of Photons from a Decaying Particle?
The discussion focuses on calculating the momentum and energy of photons resulting from the decay of a particle with rest mass m, which possesses kinetic energy equal to twice its rest energy. The particle decays into two photons traveling in opposite directions, with one photon moving in the same direction as the particle prior to decay. The momentum of the particle can be derived using the equation T=E-m=2m, leading to expressions for both the particle's momentum and the energy of each photon in terms of m.
  • Understanding of relativistic energy and momentum concepts
  • Familiarity with particle decay processes
  • Knowledge of the relationship between kinetic energy and rest mass
  • Basic grasp of photon energy equations
  • Study relativistic momentum calculations in particle physics
  • Learn about photon energy in different reference frames
  • Explore the implications of energy conservation in particle decay
  • Investigate the principles of special relativity as they apply to massless particles
Physicists, students of particle physics, and anyone interested in the principles of energy and momentum conservation in particle decay scenarios.
da_warped_1
hi wondering if i could get a little help with this question
A particle with rest mass m has kinetic energy equal to twice its rest energy. The particle decays into 2 photons which emerge in opposite directions, one traveling in the same direction as the particle before its decay. Find expressions, in terms of m for:
(a) the momentum of the particle
(b) the energy of each of the 2 photons
thanks for any help.
What help do you want? Where is the difficulty? In other words, what have you done on this yourself?
For (a), start with T=E-m=2m. Solve for E and then for p.
For (b), LT each photon's energy in the particle's rest frame (k=m/2),
to the frame moving with velocity v=p/E.
