Does Increasing Horizontal Velocity Affect Projectile Range, Time, or Height?
  • Thread starter Thread starter mikefitz
    Conceptual
The discussion centers on the effects of horizontal velocity on projectile motion, specifically addressing how changes in initial horizontal velocity (vox) impact maximum height, time of flight, and range. It is established that increasing vox while keeping vertical velocity (voy) constant will result in an increased range, while maximum height and time of flight remain unchanged. Additionally, the conversation touches on the concept of apparent weight in an accelerating elevator, concluding that a scale reading higher than actual weight indicates upward acceleration.
  • Understanding of basic physics concepts such as projectile motion and acceleration due to gravity.
  • Familiarity with kinematic equations and their application in analyzing motion.
  • Knowledge of forces acting on objects in different scenarios, including free fall and acceleration.
  • Basic grasp of the relationship between mass, weight, and apparent weight in non-inertial frames.
  • Study the effects of varying initial velocities on projectile motion using simulation tools like PhET Interactive Simulations.
  • Learn about the kinematic equations for projectile motion and how to apply them in different scenarios.
  • Explore the concept of apparent weight in non-inertial frames, particularly in accelerating elevators.
  • Investigate the relationship between vertical and horizontal components of motion in projectile analysis.
Students preparing for physics exams, educators teaching projectile motion concepts, and anyone interested in understanding the dynamics of motion under varying conditions.
mikefitz
I was looking through my book tonight before my midterm exam and came across the following conceptual questions I would like to discuss before I take the test.
A rock is thrown straight up. It reaches the top of its path and starts to fall back down. It’s acceleration on the way down, neglecting air resistance, is:
(a) greater than when it was at the top of its path.
(b) the same as when it was at the top of its path.
(c) less than when it was at the top of its path.
Acceleration on the way down due to gravity would be 9.8m/s^2. However, couldn't the acceleration on the way up be greater than that? (IE: If I were to fire a bullet straight up it would have an acceleration greater than 9.8)
A ball is launched from ground level with initial velocity components vox and voy and flies through the air, reaching a maximum height, having a certain time of flight, and reaching a certain range. How will EACH of these 3 quantities change (increase/decrease/unchaged) if we increase vox (but keep voy at its original value)?
Maximum Height-- Time of Flight-- Range
(a) increase increase increase
(b) unchanged unchanged increase
(c) decrease decrease decrease
(d) increase unchanged unchanged
(e) decrease increase unchanged
Changing Vx wouldn only change the range since x/y components are independent, correct?
A passenger who weighs 180 lbs stands on a scale in an elevator. The scales read 190 lbs. The elevator could be
(a) moving upward and increasing its speed
(b) moving upward and decreasing its speed
(c) moving downward and increasing its speed
(d) moving downward at a constant speed
Probably moving upward and increasing in speed since there is a net force on the person greater than their weight.
Thoughts?
Why - what forces are acting on it at this point?
Thoughts?
If there is an apparent increase in mass, this means that they are acceerating upwards, or decelerating downwards. So really, there are two possibilities although your choice of 4 answers only includes 1 of them.
28K
  • · Replies 21 ·
11K
