Solving the Initial-Value Problem: Step-by-Step Guide for Beginners
  • Thread starter Thread starter bobbarkernar
The discussion revolves around solving an initial-value problem involving a first-order differential equation, specifically dy/dx = -y^2 with the initial condition y(0) = 0.0625.
  • Participants discuss the integration of the differential equation and the determination of the constant C using the initial condition. There are questions about the correctness of the derived expressions and the sign of the constant.
The discussion includes attempts to clarify the integration steps and the implications of the initial condition. Some participants express confusion about the sign of the constant and the final form of the solution, while others provide affirmations and corrections regarding the integration process.
Participants are navigating through the integration of the equation and the application of the initial condition, with some uncertainty about the signs and values involved in the solution.
bobbarkernar
i have no idea on how to start this problem.
Find a solution of the initial-value problem
dy/dx= -y^2 , y(0)=.0625
so..
(1/-y^2)dy = dx
int(1/-y^2)dy=int(dx)
1/y=x+c
please if someone can help me start it or explain it to me
so..
(1/-y^2)dy = dx
1/y=x+c
Note that you have [tex]-\frac{1}{y} = x + C[/tex]. Now all you have to do is write [tex]y = -\frac{1}{x+C}[/tex] and use the initial value.
so am i solving for C?
Yes, you are.
so
C= (1/y)-x ??
so C=(1/.0625) if y(0)=.0625 ?
is this correct?
bobbarkernar said:
so
C= (1/y)-x ??
is this correct?
Yes, C = -16.
negative?
bobbarkernar said:
negative?
Yes, since [tex]y(x) = -\frac{1}{x+C} \Rightarrow y(0) = -\frac{1}{C} = 0.0625[/tex]
but the integral of -1/y^2 dy is 1/y
Yes, you're right. I apologize, that minus sign slipped through somehow. :smile: So, your answer is correct.
ok but i put the answer c=16 and it was wrong. is there another step?
ok i got it the answe is y=1/(x+16)
thank you for your help
Yes, I just wanted to write that the answer is a function, not a constant.
  • · Replies 25 ·
  • · Replies 24 ·
