Annihilation creation operator
The discussion revolves around calculating the expectation value of position \( x \) using a wave function represented as a superposition of two states, \( |1\rangle \) and \( |2\rangle \). Participants are exploring the implications of using annihilation and creation operators in this context.
  • Mathematical reasoning, Assumption checking, Problem interpretation
  • Participants are attempting to expand the expression for the expectation value and are encountering unexpected results. Questions arise regarding the notation and the properties of the operators involved, particularly the annihilation operator \( a \) and the creation operator \( a^+ \). There is also inquiry into the orthogonality of the states and the implications of the inner products yielding zero.
The discussion is ongoing, with participants clarifying their understanding of the operators and the states involved. Some have pointed out that only certain terms in the expansion contribute non-zero values, indicating a productive exploration of the mathematical structure.
Participants are working under the assumption that the states \( |1\rangle \) and \( |2\rangle \) are orthonormal, which influences their calculations and interpretations of the results.
greisen
Hey,
I am calculating the expectation value of the position x. I have the wave function
psi(x) = |1> + |2>
so I use the equation <x> = <psi|(a+a^+|psi> to calculate the mean value. So I get
(<1| + <2|)(a+a^+)(|1> + |2>)
which I reduce to
<1|a|1> + <1|a|2> + <2|a|1> + <2|a|2> + <1|a+|1> + <1|a+|2> + <2|a+|1> + <2|a+|2>
if I use the properties of annihilation and creation I get some strange results such fx
sqrt(1) <1|0> or sqrt(3)<2|3> which are totally wrong. What have I done wrong?
Thanks in advance
greisen said:
Hey,
psi(x) = |1> + |2>
which I reduce to
Thanks in advance
I am not following the notation. If a is an operator and a^ is an operator, then why is there a + after a^ and why are there no a^ in your expansion?
Maybe I have expressed the problem badly. a is the annihilation operator and a+ is the creation operator. I have a two state system |1>, |2> with a wavefunction (psi) = |1> + |2>. My problem is to perform the multiplication in order to find the expectation value:
(<1| + <2|)(a + a+)(|1> + |2>)
if I expand this calculation I get some strange results. How to multiple this? Any help appreciated - thanks in advance
greisen said:
Hey,
Thanks in advance
<1|0>=<2|3>=0
In the above sum, only two terms are nonzero.
So a|n> = |n-1> and a+|n> = |n+1>? and the states are orthogonal? Is that right? Euclid seems to know what you are doing, and it seems to be consistent with this interpretation. What are <1|1> and <2|2>? Are the states orthonormal? This is not a hint. I am asking because I want to know.
Yes the two kets |1> and |2> are orthonormale. My problem in the multiplication was the <2|3>, <1|0> which are zero.
  • · Replies 0 ·
