Thread Closed
change in planet's day length
Share Thread Thread Tools
Oct28-06, 03:49 PM   #1
This is regarding that planet question. I set up the equation as:
[tex]L_{pi} = L_a + L_{pf} = L_a + I_p \omega_{pf} \Longleftrightarrow \omega_{pf} = \frac{L_{pi} - L_a}{I_p}[/tex]
where [tex]I_p = \frac{2 M R^2}{5}[/tex]
so [tex]\omega_{pf} = \frac{L_{pi} - L_a}{\frac{2 M R^2}{5}}[/tex]
In the original problem, we're given T = 13 hours, so
[tex]T_i = \frac{13 "hours"}{"rev"} \cdot \frac{60 "min"}{1 "hour"} \cdot \frac{60 "sec"}{1 "min"} = \frac{46800 "sec"}{"rev"}[/tex]
Using the final [tex]\omega[/tex] I came up with [tex]T_f = \frac{46801.3 "sec"}{"rev"}[/tex] - isn't that a longer day? Yet the question states "But, thanks to the asteroid's angular momentum, the planet rotates faster after the imapact than it did before."
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct28-06, 06:56 PM   #2
am I just being stupid? I've done this a few times now and I keep coming up with the same answer. If it takes longer to make a revolution, the day would be longer.
Oct28-06, 10:17 PM   #3
I guess I set up the equation wrong. Using this:
[tex]L_{pi} + L_a = L_{pf} = I_p \omega_{pf} \Longleftrightarrow \omega_{pf} = \frac{L_{pi} + L_a}{I_p}[/tex]
so [tex]\omega_{pf} = \frac{L_{pi} + L_a}{\frac{2 M R^2}{5}}[/tex]
Using this new method (and adding the mass of the asteroid to the mass of the planet), I got [tex]T_f = \frac{46798.7 "sec"}{"rev"}[/tex] which means a day is shorter.
Thanks for letting me figure it out!!! (I finally got the right answer!) Ya'll are great.
Oct28-06, 11:31 PM   #4
You're quite welcome.
Thread Closed
Thread Tools
Similar Threads for: change in planet's day length
Thread Forum Replies
[SOLVED] Change in earth's day length due to water displacement Introductory Physics Homework 4
A change in length ratio question General Math 2
Other Planet's Radiation Belts. General Astronomy 2
Maybe this world is another planet's hell. General Discussion 35
