Thread Closed
Friction or some force acting on momentum of an object
Share Thread Thread Tools
Oct28-06, 07:05 PM   #1
Would forces like friction and air resistance increase momentum or decrease it?
I would think if a force acts on momentum it would decrease the momentum of an object. Is that right?
P= mv
P= Ft
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Oct28-06, 07:09 PM   #2
Recognitions:
Homework Helper Homework Help
It depends on the direction of the force with respect to velocity. In the case of friction and air resistance, the absolute value of the momentum will always decrease, yes.
It should be noted that if the momentum is negative, it will actually increase
Oct28-06, 07:10 PM   #3
Of course it would decrease it, but this is assuming a certain refrence frame.
If for some reason the refrence frame were moving, then friction could increase momentum.
Oct28-06, 07:12 PM   #4
or I guess it could decrease it and then start increasing it.
<<just to confuse you :) >>
Oct29-06, 12:13 AM   #5
I am sure you are familiar with friction decreasing momentum. An example of friction inceasing momentum would be the way a car accelerates. The force that pushes the car forward is actually friction from the road on the tyre. The car accelerates and increases its momentum.
Thread Closed
Thread Tools
Similar Threads for: Friction or some force acting on momentum of an object
Thread Forum Replies
Two forces acting on an object Introductory Physics Homework 2
How do you find the frictional force acting on an object if it is decelerating? Introductory Physics Homework 6
Force acting on rotatble object Classical Physics 2
friction acting on a spinning ice skater Introductory Physics Homework 10
Momentum + Friction force = me depressed Introductory Physics Homework 4
