How much current flows through the bar?
  • Thread starter Thread starter MrDMD83
    Current
The discussion focuses on calculating the current flowing through a sliding aluminum rod on tilted conducting rails within a vertical magnetic field. Given the parameters, including a magnetic field strength of 0.053 T, a rod mass of 0.20 kg, and a length of 1.6 m at a 30.0° angle, the formula F = ILBsin(x) is utilized to derive the current. The constant velocity of the rod indicates that the forces are balanced, allowing for a straightforward application of electromagnetic principles to find the current.
  • Understanding of electromagnetic induction principles
  • Familiarity with the formula F = ILBsin(x)
  • Knowledge of basic physics concepts such as force, mass, and velocity
  • Ability to perform calculations involving trigonometric functions
  • Study the principles of electromagnetic induction in detail
  • Learn about the applications of the Lorentz force in different contexts
  • Explore the effects of varying magnetic field strengths on induced currents
  • Investigate the relationship between frictionless motion and electromagnetic forces
Physics students, educators, and professionals in engineering fields who are interested in understanding the dynamics of electromagnetic systems and current generation through motion.
MrDMD83
The two conducting rails in the drawing are tilted upwards so they make an angle of 30.0° with respect to the ground. The vertical magnetic field has a magnitude of 0.053 T. The 0.20 kg aluminum rod (length = 1.6 m) slides without friction down the rails at a constant velocity. How much current flows through the bar?
What have you tried so far?
F=ILBsin(x)
  • · Replies 22 ·
