Register to reply
Number of moles = volume/molar mass?
by Tiptronic
Tags: mass, moles, number, volume or molar
Share this thread:
Tiptronic
#1
Oct30-06, 06:54 PM
P: 12
Question:
0.2ml glucose solution.
Molar mass of glucose = 180 g/mol
How many moles?
If it was a mass in grams it would be easy:
n = mass/molar mass
But what do I do now its a volume?
Can I still use the same relationship, since grams is equivalent to ml isnt it?
If yes, then what does the unit of 'n' become...ml/mol?
Please help. Thanks.
Phys.Org News Partner Science news on Phys.org
Apple to unveil 'iWatch' on September 9
NASA deep-space rocket, SLS, to launch in 2018
Study examines 13,000-year-old nanodiamonds from multiple locations across three continents
geoffjb
#2
Oct30-06, 06:59 PM
P: 167
Quote Quote by Tiptronic
Question:
How many moles?
n = mass/molar mass
Grams are not equal to mL. [itex]cm^{3}[/itex] are equal to mL.
Are you given the concentration (measured as M or mol/L)?
Gokul43201
#3
Oct30-06, 06:59 PM
Emeritus
Sci Advisor
PF Gold
Gokul43201's Avatar
P: 11,155
Question:
How many moles?
The question is either incomplete or wrong. Please post the COMPLETE question, EXACTLY as it is given to you.
n = mass/molar mass
Correct.
No, you can't.
The number of moles only has one unit : "moles". Anything that is dimensionally different from this can not be a unit for the number of moles.
Tiptronic
#4
Oct30-06, 07:09 PM
P: 12
Thanks for the quick replies guys.
Glucose + 3 Phenylhydrazine hydrochloride --> Osazone + Phenylamine + Ammonia + Water
These are what Im using in this reaction:
0.2ml of a Lucozade drink (not diluted, so its 100% concentrated as you'd buy it off the shelf)
0.4g Phenylhydrazine hydrochloride
0.6g crystallized sodium acetate
4ml distilled water.
What i need to do is justify the use of 0.2ml of the glucose drink by using the ratio in the equation (1:3) and by working out the no. of moles of Phenylhydrazine Hydrochloride... n = 0.4/142.5 = 2.8 x 10^23
Now I need to work out the number of moles of the Glucose drink.
Any ideas?
Tiptronic
#5
Oct30-06, 07:18 PM
P: 12
Just thought of something:
Could i use this:
n = concentration x volume
Though i doubt "100%" is a concentration that can be used in the above relationship???
geoffjb
#6
Oct30-06, 07:23 PM
P: 167
Could i use this:
No, 100% is not a concentration (since n = concentration x volume, with n in units of moles and volume in units of L, then concentration must have units of mol/L).
Tiptronic
#7
Oct30-06, 07:29 PM
P: 12
So, there is no way I can work out the concentration from the information I have?
So could you tell me how I can justify the use of 0.2ml of the Lucozade Glucose drink?
My head hurts. :(
Tiptronic
#8
Oct30-06, 07:46 PM
P: 12
Sorry Im an idiot.
The whole point of this investigation was to find the glucose amount: I did an experiment and found that in one bottle (380ml) there is 47g of glucose.
Thus, if 380ml contained 47g, then 0.2ml would contain: (0.2ml/380ml) x 47g = 0.025g
So now I know this:
0.2ml of 100% concentrated glucose containing 0.025g glucose.
Glucose molar mass = 180 g/mol
So can I now find 'n'?
n = mass/Molar mass
n = 0.025/180
n = 0.000139 mol
Please tell me this works now? And does this get me any closer to justifying why Ive used 0.2ml in this Osazone test?
The Glucose is 0.000139 mol and the Phenylhydrazine hydrochloride is 0.0028 mol.
According to the equation the ratio is 1:3.
0.0028/0.000139 = 20 so its not as if there is three times as many molecules in the Phenylhydrazine hydrochloride than the glucose...
Help...
geoffjb
#9
Oct30-06, 07:52 PM
P: 167
Sorry Im an idiot.
So now I know this:
n = mass/Molar mass
n = 0.025/180
n = 0.000139 mol
Thanks.
Get rid of "100% concentrated glucose"; it is wrong (you have a solution of glucose, meaning dissolved solute [glucose] in a solvent [likely water]).
Assuming your molar mass is exactly 180 g/mol, then I get 1.37E-4 (not 1.39E-4, as you get, although it might not matter much in the end, depending on sig figs).
Based on what you said you needed to do, you can take this amount and determine whether or not it is a reasonable amount of glucose needed in the reaction. If it is, you have justified yourself.
Tiptronic
#10
Oct30-06, 08:06 PM
P: 12
Thank you for the reply geoffjb.
Would this be a good explanation?
0.0028/0.000139 = 20 (2sf)
This means that the phenylhydrazine hydrochloride is more than 3 times the amount of glucose (in terms of mols) thus satisfying the ratio of the equation.
Looking at the equation:
The Phenylhydrazine hydrochloride should be in excess so that all the glucose is turned into the osazone. I have shown that the Phenylhydrazine hydrochloride is definately in excess, satisfying the ratio of the equation, and thus this justifies using a small quantity of glucose drink (0.2ml) for the osazone test.
How does that sound?
geoffjb
#11
Oct30-06, 08:15 PM
P: 167
If the theoretical ratio is 1:3 and the actual ratio is 1:20, are you justified in using only 0.2 mL of glucose?
If this is a scientific lab report, don't use "I".
Tiptronic
#12
Oct30-06, 08:23 PM
P: 12
Firstly, do I not need to multiply the 0.0028 mol by 3, if the equation says that 3 mols reacts with 1 mol of glucose?
So you're saying 0.2ml is too little? Doesnt 1:20 means that the phenylhydrazine hydrochloride is in excess? Then isnt that ok, since there is enough to react with all of the glucose? I dont quite understand.
geoffjb
#13
Oct30-06, 08:27 PM
P: 167
Based on your equation, three moles of phenylhydrazine hydrochloride are required to react with one mole of glucose. Your multiplication factors must account for this.
You're right; it's definitely enough to react with all the glucose. However, since I don't know the original wording of the question, I don't know if such excess is "justified", as you were initially asking. Only you can determine this.
Tiptronic
#14
Oct30-06, 08:33 PM
P: 12
Quote Quote by geoffjb
Sorry, I didnt understand. So do I multiply the 0.0028 mol of Phenylhydrazine hydrochloride by 3, and then form a ratio from that?
Its part of my write-up of my investigation. So Im ok in saying that such a small amount is justified, as the Phenylhydrazine hydrochloride should be in excess anyway for best results of this Osazone test?
geoffjb
#15
Oct30-06, 08:41 PM
P: 167
Yes, in determining limiting reagents, you use a multiplication factor.
Okay.
Tiptronic
#16
Oct30-06, 08:49 PM
P: 12
Thanks for that, really appreciate it.
Btw, you wouldnt happen to know of any websites with information on the osazone, why its solid at room temperature and why it precipitates out? Ive looked a lot but to no avail.
Thanks.
geoffjb
#17
Oct30-06, 09:02 PM
P: 167
Thanks.
The physical state of osazone at room temperature would be dependent on the intermolecular forces between the molecules.
It would precipitate out simply because it is insoluble in the solvent. Remember that "like dissolves like".
More information on either question requires more in-depth analysis of the molecular structure of osazone.
This page might help.
Tiptronic
#18
Oct30-06, 09:06 PM
P: 12
Thanks again. I hope I havent taken up too much of your time.
Register to reply
Related Discussions
Determining Number of Moles Question Biology, Chemistry & Other Homework 4
Miscellaneous calculation with moles, mass and gas volume Biology, Chemistry & Other Homework 3
What is the molar mass of Introductory Physics Homework 1
Calculating the number of moles of air Introductory Physics Homework 3
Molar mass Chemistry 7
