Zero Torque and static equilibrium
The discussion focuses on solving a static equilibrium problem involving a stick and a bowling ball. The stick, with a mass of 0.206 kg and a length of 0.450 m, is positioned at a 30° angle to the horizontal while resting on a rough floor and in contact with the bowling ball, which has a diameter of 21.1 cm. Key calculations include determining the force exerted on the stick by the bowling ball, the horizontal component of the force from the floor, and the upward component of that force. The solution requires applying the principles of static equilibrium, specifically ensuring that the sum of forces and torques equals zero.
  • Understanding of static equilibrium principles
  • Ability to draw and interpret free body diagrams
  • Knowledge of torque calculations
  • Familiarity with forces acting on inclined planes
  • Study the principles of static equilibrium in detail
  • Learn how to construct and analyze free body diagrams
  • Explore torque calculations and their applications in physics
  • Research the effects of friction on static objects
Students studying physics, particularly those focusing on mechanics and static equilibrium, as well as educators looking for practical examples to illustrate these concepts.
map7s
A stick with a mass of 0.206 kg and a length of 0.450 m rests in contact with a bowling ball and a rough floor, as shown in the figure below. The bowling ball has a diameter of 21.1 cm, and the angle the stick makes with the horizontal is 30°. You may assume there is no friction between the stick and the bowling ball, though friction with the floor must be taken into account.
(a) Find the magnitude of the force exerted on the stick by the bowling ball.
(b) Find the horizontal component of the force exerted on the stick by the floor.
(c) Repeat part (b) for the upward component of the force.
I had absolutely no idea how to get started on this problem.
Draw a force body diagram. The stick is just sitting there so the sum of the forces in each direction must be zero and the sum of the torques must be zero.
9K
  • · Replies 18 ·
