Solving Hund's Rule Q: Gd [Xe] 6s^2,4f^7,5d^1
  • Thread starter Thread starter Old Guy
The discussion focuses on determining the ground state L and S for Gadolinium (Gd) with the electron configuration [Xe]6s^2,4f^7,5d^1. The user calculates Smax as 4, accounting for the spins of the 5d^1 and 4f^7 electrons. However, confusion arises regarding the calculation of L, as the user initially assumes Lmax to be 7. The correct total angular momentum quantum number L is clarified to be 2, based on the contributions of the magnetic quantum numbers m_l from the electron configuration.
  • Understanding of quantum numbers, specifically magnetic quantum numbers (m_l).
  • Familiarity with Hund's Rule and its application in electron configurations.
  • Knowledge of the Pauli exclusion principle and its implications for electron arrangements.
  • Basic concepts of angular momentum in quantum mechanics.
  • Study the application of Hund's Rule in transition metals and lanthanides.
  • Learn about the calculation of total angular momentum L in multi-electron systems.
  • Explore the implications of the Pauli exclusion principle on electron configurations.
  • Investigate the properties of Gadolinium and its electron configuration in detail.
Chemistry students, physicists, and educators seeking to deepen their understanding of electron configurations and quantum mechanics, particularly in relation to transition metals and lanthanides.
Old Guy
I'm certainly missing something here. The problem is to find the ground state L and S for Gd, with a configuration given as [Xe]6s^2,4f^7,5d^1.
I start by calculating Smax. I'm figuring you get 1/2 for the 5d^1 electron, plus (since the f level has room for 14 electrons, all 7 can have +1/2 spin) 7/2 give Smax = 4.
How do I get L? It would seem that Lmax would be 4 for the 5d^1 electron and 3 for the others, making a total of 7. The book says it should be 2, and I can't see how, for example, the Pauli exclusion principle should get me there. Any help would be appreciated - I really want to understand the concept as much as deal with this problem. Thanks.
The magnetic quantum numbers m_l have 2l+1 possible values ranging from -l to +l in integer steps. The s^2 has only 0, the p^7 has one of every m filled, so the net contribution from these is zero. The one remaining electron in the d^1 has a maximum value of 2, so it looks like 2 is it.
  • · Replies 23 ·
9K
