Abstract Algebra - Direct Product Question
The discussion revolves around finding a non-trivial group G such that G is isomorphic to G x G, specifically within the context of abstract algebra. Participants explore the properties of groups, particularly infinite groups, and the implications of isomorphism.
  • Participants discuss the characteristics of the group Z and its relation to Z x Z, questioning the validity of the original poster's reasoning and map description. There are inquiries about the requirements for proving isomorphism and the nature of generating sets for G and G x G.
The conversation is active, with participants providing feedback and prompting further exploration of the topic. Some guidance has been offered regarding the nature of generating sets and the need for rigorous proof of the proposed map's properties.
There is an emphasis on the need for non-cyclic groups and the exploration of generating sets, with participants acknowledging the complexity of proving isomorphisms in this context.
BSMSMSTMSPHD
I'm supposed to find a non-trivial group G such that G is isomorphic to G x G.
I know G must be infinite, since if G had order n, then G x G would have order n^2. So, after some thought, I came up with the following. Z is isomorphic to Z x Z.
My reasoning is similar to the oft-seen proof that the rationals are countable.
Picture a grid with dots representing each element in Z x Z. Now, starting at the origin, trace a circuitous path (in any direction, but always a tight spiral) and define a map that sends 0 to (0,0), 1 to the next point, -1 to the next point, 2 to the next point, etc.
Is it enough to describe this map in the way I have, or do I need further information (or am I wrong?)
Thanks.
Z x Z is not isomorphic to Z. Z x Z is not cyclic. You might think about the group of integer functions on the integers.
That describes a map... (although having only a heuristic description makes it hard to prove things about it)
But you've yet to prove that your map is a homomorphism, that it has an inverse, and that its inverse is a homomorphism.
Thanks guys. Back to the drawingboard.
Hrm. I hate to give big hints like this, but...
If a generating set of G must contain at least n elements... then (heuristically speaking) how many elements must a generating set of GxG contain?
I don't like to give answers like this, but I haven't the slightest idea.
Well, how many generators does it take to generate the subgroup Gx1 of GxG?
I would say n - same as for G.
And what about 1xG? So what does that suggest will be (roughly) true, if you want to generate all of GxG?
You would need 2n?
Right. In particular, if G is finitely generated, then...
(this is not a rigorous proof -- I don't know if weird things will happen that allow you to use less than 2n... but we're not looking for proofs here, we're searching for examples!)
