Using Series Resistors for Audio Sources: Is Jumpering Channels Safe?
The discussion centers on the use of series resistors in passive summing mixers for audio sources, specifically addressing the safety of jumpering left and right channels from devices like VCRs. It is established that while many in the AV industry have successfully jumpered channels to create mono signals, this practice can lead to distortion due to impedance mismatch. The consensus indicates that using a proper summing mixer is advisable to prevent potential damage to the destination device and ensure audio quality.
  • Understanding of passive summing mixers
  • Knowledge of series resistors in audio applications
  • Familiarity with impedance matching concepts
  • Experience with audio signal routing and mixing techniques
  • Research the specifications and benefits of using dedicated audio summing mixers
  • Learn about impedance matching techniques in audio systems
  • Explore the effects of distortion in audio signals due to improper channel jumpering
  • Investigate best practices for combining audio signals from multiple sources
Audio engineers, AV technicians, and anyone involved in audio mixing and signal processing who seeks to understand the implications of channel jumpering and the importance of using appropriate mixing equipment.
avandmore
My understanding of a passive summing mixer is to use series resistors to limit the voltage from multiple sources so as to not over drive the destination? If you are combining two audio channels say from a VCR and jumper the left and right channel will this have serious reprocutions for the destination? For years in the AV business, I and many others, have been jumpering left and right channels on singal source to make a mono signal without using a summing mixer. I am being told this should never be done?? Anyone prove or disporve this?
Not using a mixer will cause distortion due to impedence mismatch.
How much you will notice this depends on the source material.
  • · Replies 65 ·
13K
