Expansion of y=sinh-1(x) in terms of x using inversion of power series method
The discussion revolves around expressing the inverse hyperbolic sine function, y = sinh-1(x), as a power series in terms of x. Participants explore the relationship between y and x through the expansion of the sinh function and the inversion of power series.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss expanding the sinh function using its exponential series and inverting the resulting series to express y in terms of powers of x. There are questions about how to compare coefficients of the power series and how to handle terms when substituting the series into the equation.
The discussion includes various attempts to derive coefficients for the power series, with some participants successfully identifying specific coefficients and others expressing confusion about the process. Guidance has been offered regarding the comparison of coefficients, and some participants are actively working through the implications of their findings.
There is an acknowledgment of potential confusion regarding the expansion and comparison of terms, particularly with respect to the presence of even and odd coefficients in the series. Participants are also noting the importance of factorials in their expansions.
mind2work
I need to express the sinh-1(x) as a power series in terms of powers of x. I have written the expression as x=sinhy and expanded the sinhy using the exponential series to give x = y+(1/3)y^3+(1/5)y^5+... I guess I need to expand the y=sinh-1(x) and compare or equate the coefficients. If this doesn't make sense it's because I'm confused, as you can tell. I expanded the sinhy and expressed it as a power series in y. I need to invert the x=y+(1/3)y^3+(1/5)y^5+... to then express it in terms of power terms of x. Does this sound right??
Now, assume there exists a power series of y in terms of x, i.e:
[tex]y=\sum_{i=0}^{\infty}a_{i}x^{i}[/tex]
Insert this in the y's places, compute&enjoy the first a's.
arildno,
Thanks for the help. That seems too easy. So I would insert the power series you mentioned in the place of each y. For the y^3 term, for example, I would cube the power series. I would assume you must expand the power series to get a collection of x terms and sum them up??
You're right.
Compare the coefficients of each power of x.
When you insert the power series for y, the right-hand side must be IDENTICALLY EQUAL to x, that gives you the equations to determine the a's.
Ok, another brain cramp. Once I put the power series in for each y, expand, and sum I get and expression like x=(a1)*x-term+(a3)*x-term^3+...How am I going to compare coefficients with one x on the left side and many x-terms on the right side??
Ok, do you mean compare the coefficients of the y terms from the expansion of the sinhy to the coefficients of the expansion you just talked about??
arildno,
Let me try it and see what happens. I'm trying to mentally visualize too far ahead. It will probably be more obvious when I expand everything. Check back later this evening if you can and don't mind.
First of all, [itex]a_{0}=0[/itex], since there isn't any constant term on your left-hand side.
Thus, the only y-power containing a [itex]x^{1}[/itex]-term on the right-hand side is the [itex]y^{1}[/itex]-term.
Thus, we get [itex]a_{1}=1[/itex], by comparing coefficients.
Note now that the only place where there is a [itex]x^{2}[/itex] term is in the [itex]y^{1}[/itex]-term, thus [itex]a_{2}=0[/itex]
Inductively, it follows that all even coefficients must be zero, that is we may write:
[tex]y=\sum_{i=0}^{\infty}a_{2i+1}x^{2i+1}[/itex]<br /> <br /> Now, an [itex]x^{3}[/itex]-term appears in both the y-and [itex]y^{3}[/itex]-term, and the coefficients must satisfy the equation:<br /> [tex]0=a_{3}+\frac{a_{0}^{3}}{3}=a_{3}+\frac{1}{3}\to{a}_{3}=-\frac{1}{3}[/itex]<br /> <br /> To calculate [itex]a_{5}[/itex], there are three terms appearing, from the [itex]y,y^{3},y^{5}[/itex]-terms, respectively.<br /> This yields the equation:<br /> [tex]a_{5}+\frac{1}{3}*3a_{1}^{2}*a_{3}+\frac{a_{1}^{5}}{5}=0[/itex]<br /> or:<br /> [tex]a_{5}-\frac{1}{3}+\frac{1}{5}=0\to{a}_{5}=\frac{2}{15}[/tex]<br /> Thus, to fifth order, we have:<br /> [tex]y=x-\frac{x}{3}+\frac{2}{15}x^{5}[/tex]<br /> <br /> Now, since I haven't anything better to do, here's the equation by which we may determine [itex]a_{7}[/itex]:<br /> [tex]a_{7}+\frac{1}{3}(3*a_{1}^{2}*a_{5}+3*a_{3}^{2}*a_{1})+\frac{1}{5}(5*a_{1}^{4}*a_{3})+\frac{1}{7}a_{1}^{7}=0[/tex]<br /> Do you get the pattern now?[/tex][/tex][/tex]
I tried to do this and got coefficients for the x terms, if my memory serves me right, sinh-1(x)=x-1/6(x)+3/40(x^3). I turned the homework in this morning. I am going to take your notes here and rework the problem when I get it back. I know this will be on our next test. Thanks a lot for the help...
You're probably right.
Note that you forgot the factorial sign in your expansion of sinh(x).
When I posted my reply, I forgot that those !'s should be included.
  • · Replies 17 ·
