What is the significance of the A field in understanding the Marinov Motor?
  • Context: Undergrad
  • Thread starter Thread starter Jdo300
    Field
The discussion centers around the significance of the "A" field, or magnetic vector potential, in understanding the Marinov Motor. Participants explore its theoretical implications, its role in the context of the motor's operation, and its relationship to established physics concepts, particularly in quantum theory.
  • One participant seeks introductory information about the "A" field, noting its connection to magnetic potential and its absence in standard physics education.
  • Another participant explains that the "A" field is the magnetic vector potential and references Helmholtz's theorem regarding the relationship between vector fields and their curls.
  • A participant questions the relevance of the Marinov Motor to the "A" field, suggesting that another motor design operates based on heating and deformation rather than magnetic fields.
  • Further inquiry is made into the physical significance of the "A" field, including its interactions with physical entities and whether it is merely a mathematical abstraction.
  • A quote from Feynman is presented, emphasizing the importance of vector and scalar potentials in modern physics, particularly in quantum electrodynamics, suggesting a shift away from traditional electric and magnetic fields.
Participants express varying views on the relevance and interpretation of the "A" field in relation to the Marinov Motor. There is no consensus on its physical significance or its role in the motor's operation, indicating ongoing debate and exploration of the topic.
Participants reference different interpretations and applications of the "A" field, highlighting potential limitations in understanding its significance without further context or definitions. The discussion also reflects uncertainty regarding the relationship between the Marinov Motor and established physical principles.
Jdo300
The "A" Field?
Hello All,
A while ago, I had a chance to read this research paper that was trying to explain how the "Marinov Motor" works. In the paper, they explain that it does not use regular induction through magnetic B fields, but instead makes use of the "A" field. I don't remember reading anything about this field in my physics book and was wondering if anyone could point me in the right direction to some good introductory info about it. I heard it has to do with magnetic potential or something. In case you are interested, I also attached the file I was looking over.
Thanks,
Jason O
It is the magnetic vector potential. (One form of one of) Hemlhotz's theorem says that any divergenceless vector field [itex]\vec{B}[/itex] can be written as the curl of of a vector field:
[tex]\vec{B}=\nabla \times \vec{A}[/tex]
Note that just as the electric potential or the potential energy function in mechanics, the potential vector [itex]\vec{A}[/itex] is not unique but rather for any [itex]\vec{A}[/itex] such that
[itex]\vec{B}=\nabla \times \vec{A}[/itex], [itex]\vec{A}+\nabla\lambda[/itex] where [itex]\lambda[/itex] is any (properly bahaved) scalar function is another vector potential for [itex]\vec{B}[/itex].Additionally (though this information might be superfluous at this point, it is very important), according to (another version of another) Helmhotz theorem, any vector field can be written as a function of its curl and its divergence only. Since we only need that the curl of A be B, we can litrally choose any value we want for the divergence of A.
This paper doesn't seem to refer to what google calls the http://www.electricstuff.co.uk/bbmotor.html" . The latter does not really depend on fields; a current selectively heats and deforms ball bearings so that they (through frictional forces) apply an acceleration. :smile:
That is not the Marinov motor I am looking into. Here is another document referencing it:
http://redshift.vif.com/JournalFiles/Pre2001/V05NO3PDF/v05n3phi.pdf
@quasar987,
Thanks for the info. What physical significance does the A field have? What physical entities does it react with? Or is it just some sort of mathematical abstraction?
Thanks,
Jason O
I quote Feynman:
Nevertheless, the vector potential A (together with the scalar potential V that goes with it) appear to give the most direct description of the physics. This becomes more apparent the more deeply we go into the quantum theory. In the general theory of quantum electrodynamics, one takes the vector ans scalar potentials as the fundamenta quantities in a set of equations that replace the Maxwell equations: E and B are slowly disapearing from the modern expression of physical laws; they are being replaced by A and V.
From lecture 15 chapter 5 of volume 2.
  • · Replies 23 ·
  • · Replies 25 ·
