Newton (iterative) method to solve a diophantine equation
The discussion revolves around the application of the Newton method and other iterative methods to solve the Diophantine equation \( Nx^2 - y^2 = 1 \). Participants explore the nature of solutions, including the existence of integer and non-integer solutions, and delve into the implications of Pell's Equation.
  • One participant questions how the Newton method could be applied to the equation, noting the potential for non-integer solutions.
  • Another participant asserts that there are uncountably many solutions to the problem and suggests that numerical methods cannot differentiate between integer and non-integer solutions.
  • Several participants discuss the properties of Pell's Equation, indicating that solutions exist under certain conditions, such as when \( N \) is composed of primes congruent to 1 modulo 4.
  • One participant elaborates on the relationship between solutions to \( X^2 - NY^2 = -1 \) and \( X^2 - NY^2 = 1 \), suggesting that finding one solution leads to an infinite number of solutions.
  • Another participant presents a specific case where \( N \) is a perfect square and discusses the implications for the solutions.
  • There are references to modular arithmetic and conditions under which certain equations have no integer solutions.
Participants express differing views on the applicability of the Newton method and the nature of solutions to the equation. There is no consensus on how to approach the problem or the validity of certain proposed methods.
Participants mention various mathematical properties and conditions that affect the existence of solutions, but these are not resolved or universally accepted within the discussion.
Karlisbad
My question is..how could we use Newton method (or other iterative method ) to solve:
[tex]Nx^2 -y^2=1[/tex] ?? :confused: :confused:
The main problem i see is that the equation before could have some "non-integer" solutions note that (1) can be put in the form:
[tex]\sqrt(Nx^2 -1)=y[/tex]
Jose, or whatever psuedonym they force you to post under these days, please, can I ask you to just think for *one second* before posting asinine garbage like this? There exist *uncountably* many soultions to this problem. Numerical solutions cannot distinguish between the integer and non-integer solutions. The classical (hundreds of years old) theory of binary quadratic forms might be of interest. It is a subject that every mathematician has forgotten more about than you will ever learn.
The equation in integers X^2-NY^2=+/- 1 is known as the Pell's Equation which had little to do with Pell, but was first understood by Fermat.
A solution to X^2-NY^2=-1 is possible when N is composed of primes congruent to 1 Modulo 4. However, it is also true for N=2. (Thus a solution can be found for N=5, 2^2-5*1^2=-1.) If one solution can be found, in general there are an infinite number of solutions.
The exact answer for cases to the -1 where 2^n is a factor of N is rather tricky and I note from Wolfram. http://mathworld.wolfram.com/PellEquation.html:
"..and that cannot be doubly even (i.e., divisible by 4).
However, (the above) conditions are not sufficient for a solution to exist, as demonstrated by the equation , X^2-34Y^2=-1 which has no solutions in integers (Nagell 1951, pp. 201 and 204)."
However, the equation X^2-20Y^2=1 is satisifed by X=9, Y=2. This comes about because if we have a solution to X^2-NY^2=-1. Then we can "look down the road" and look at this equation:
(X^2+NY^2)^2-N(2XY)^2 which when expanding and collecting terms reduces to X^4-2N(XY)^2 +N^2Y^4=(X^2-NY^2)^2 =(-1)^2=1.
But the term -N(2XY)^2 =-4N(XY)^2 so that we have an N that has been multipled by 4, however we are solving for the plus 1.
Also if X^2-4pY^2=-1, then X^2==-1 (Mod 4), but this is not possible for even squares and all odd squares are congruent to 1 mod 4 and mod 8.
Taking your approach Karlisbad, suppose N is a perfect sqaure say N = M^2 then
[tex]y^2 = (Mx-1)(Mx+1)[/tex]
Since Mx-1 and Mx+1 are coprime each must be a perfect square to satisfy the equation that of course is impossible since their difference is 2 whereas the difference of any two consecutive squares is greater than that (2x+1)
Consider, let M be the largest square integer less than N, and K^2 = M.
[tex]y^2+1 = Nx^2[/tex]
This is the same thing as saying
[tex]y^2+1 = \sum_{i=1}^{N}x^2[/tex]
Parametrize y as y = x + k
[tex](x+k)^2+1 = = k^2x^2 + 2xk + k^2 +1= \sum_{i=1}^{N}x^2[/tex]
Suppose N > k^2 we have
(N-k^2)x^2 - 2xk -k^2-1 = 0
Nx^2 - k^2x^2 = k^2 + 2xk + 1
Let x = 1 and we get
N - k^2 = (k+1)^2
N = (k+1)^2 + k^2
A very long way to say that if x = 1 then you are looking for
y^2+1 = N, but for any integer y you can easily find N.
Let x = 2 and you get y^2 = 4N-1
NO solutions because 3*3 =1 mod 4
Let x = 3 you get y^2 = 9N-1
So do this
(sx^2+r)^2 = x^2N-1
s^2x^4 + 2rsx^2+r^2 = Nx^2-1
r^2 = -1 mod x^2
which means that x^2-1 is a perfect square which is false for x>1. It expects this x^2-1 = t^2 , (x+t)(x-t)=1 in integers that is only satisfied buy x =1, t=0
Playdo: Taking your approach Karlisbad, suppose N is a perfect sqaure say N = M^2 then
If N was a perfect square we would have the form u^2-v^2 =1. Giving the trivial solution u=1, v=0.
10K
