Computing the range for a rational function involving absolute value
The discussion revolves around finding the range of the rational function y=\frac{|x+2|}{x}, with participants exploring the implications of absolute value and the function's behavior across different intervals. The subject area includes rational functions and absolute value properties.
  • Participants discuss the definition of absolute value and its application to the function for different cases of x. Some participants attempt to analyze the function's behavior in specific intervals, while others question the clarity of the domain specification and the implications of defining it.
Some guidance has been offered regarding the use of absolute value definitions to rewrite the function for analysis. There are multiple interpretations of the domain and range, with participants expressing differing views on what constitutes a proper domain specification.
Participants mention constraints related to homework requirements, such as needing to understand asymptotes and the overall behavior of rational functions. There is an ongoing debate about the clarity and intent of the original question regarding domain specification.
Checkfate
Hi. I need help computing a range.
The question is : Find the domain and range of [tex]y=\frac{|x+2|}{x}[/tex].
The domain is obvious, x can't be 0, (-inf,0,) U (0,inf). But how do I find the range?? Can someone help me out? I have tried messing around with the definition of absolute value... if x>0 then |x| = x and if x<0 then |x| = -(x) but it just adds to the confusion, it probably doesn't help that I am running on like 4 cups of coffee. Anyways, thanks for the help :approve:
Hello Checkfate,
you can continue to use the definition of absolute value and rewrite the function for both cases. For [itex]x\geq-2[/itex] you would get
[tex]y=\frac{|x+2|}{x}=\frac{x+2}{x}=1+\frac{2}{x}[/tex]
and you can discuss the range of this function for [itex]x\in[-2,0)[/itex] and [itex]x\in(0,\infty)[/itex].
(similar for the case of [itex]x<-2[/itex])
Regards,
nazzard
Okay, I came to the right answer... this is how I did it
I started as you suggested, by first working with the function as defined when [itex]x\geq-2[/itex] and got the equation [tex]y=1+\frac{2}{x}[/tex]. I then had to do some thinking... in the interval [-2,0) y starts out at a maximum of 0 and then quickly declines from that point on as [tex]\frac{2}{x}[/tex] gets larger and larger, in a negative fashion. Then after 0, [tex]\frac{2}{x}[/tex] starts out infinitely large and comes down and tends to a minimum of 1 as x gets larger. So the range for that interval is [tex](-\inf,0] U (1,\inf)[/tex]... Then I look at when [tex]x<-2[/tex] and note that as x decreases, [tex]\frac{-2}{x}[/tex] gets closer to zero and this the function tends towards -1. So the range in this interval is [tex](-1,0}[/tex]... This gives a combined range of [tex](-\inf,0] U (1,\inf)[/tex].
Thanks a lot :)
Why is the domain obvious?
I don't get that at all.
Please tell me.
Because with |x+2|/x, the only value of x that will mess it up is 0... Division by zero is undefined :P Everything else is fair game.
Well, why can't its domain be [2,4], then?
Or the set of points [itex]\{-1,3.14,57\}[/itex]?
It is meaningless to supply a function without specifying its domain.
What you have specified, is known as the MAXIMAL domain of the function within the real number set.
But isn't agreeable that when you are asked to specify the domain of a function, what is being asked for is all the possible x's that can be plugged into the function? Unless you are supplied with a graph of the function, then you could only go on what you see.
I do see your point though :)
It is obvious that that is what the dumb exercise maker MEANT.
However, that does not excuse the exercise maker for making an improper question!
He should have asked something like:
"Determine the greatest set of real numbers that can serve as the domain of the function"
i have to do a portfolio on rational functions, so i am supposed to figure out everuthing about asymptotes, range, domain, etc. all by my self. so far i have been successful in figuring out the domain but still don't know how to find the range of a rational function. for ex. 1/x+3
  • · Replies 22 ·
  • · Replies 23 ·
