| Thread Closed |
Retraction math help |
Share Thread | Thread Tools |
| Nov3-06, 10:20 AM | #1 |
A subgroup H of a group G is a retract of G if there exists a homomorphism [itex]q\,:\,G \rightarrow H[/itex] such that [itex]q(h) = h[/itex] for all [itex]h \in H[/itex]. This map, q, is called the retraction from G onto H.
If my definition of a retract is correct then could I form a subgroup, K, of G that consists of the kernel of the retraction? That is, [tex]\mbox{ker}(q) = K < G[/tex] So K is the subgroup consisting of all elements in G that get mapped to the identity of H. Obviously, this is a normal subgroup of G and we have [itex]G = KH[/itex] and [itex]K \cap H = \{e_H\}[/itex] (from wikipedia). The group G, then, should be the semi-direction product of K and H. Is this right? Now, since H acts on K by conjugation: [tex]k \mapsto hkh^{-1}[/tex] this defines a group homomorphism [tex]p\,:\,H \rightarrow \mbox{Aut}(K)[/tex] In other words, given a group G, and a subgroup H, one can set K to be the subgroup of G consisting of elements of G that get mapped to the identity of H under the retraction. This set K is then normal, and one then has a homomorphism, p, from H into the automorphism group of K. Then the semi-direct product [itex]K \rtimes [/itex] is a group consisting of pairs [itex]hk[/itex] with multiplication [tex](h_1k_1)\cdot (h_2k_2) = (h_1 h_2)(p(h_1)(k_1)k_2)[/tex] and we also get [tex]hkh^{-1} = p(h)(k)[/tex] Now, my main question (and the reason why I brought the semi-direct product up) is this: Is the existence of a group G, which is not simple (that is, a group whose normal subgroups are not necessarily the trivial group and the group itself) and whose only only retracts are G itself, and the trivial subgroup, possible? I figured that such a group did exist. It had to be the following things: 1] It has to be a group. 2] It must not be simple. 3] It must have trivial retracts. I figured that the semi-direct product [itex]K \rtimes H[/itex] was not quite what I wanted. It is a group (by definition), it is not simple because it contains K and H as subgroups (at least), but it has H as a retract! Therefore it fails #3 of the 3 restraints. Is this all correct so far? Does anyone know of a group which satisfied all three conditions? I thought the semi-direct product came pretty close. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov3-06, 08:34 PM | #2 |
Recognitions:
Z4 is a non-simple group with only trivial retracts. Double check this.
| Nov5-06, 08:42 PM | #3 |
Recognitions:
as is Z/p^n for all primes p, all n > 1.
| Nov5-06, 10:40 PM | #4 |
Wow, how did you guys come up with such easy-looking answers!?
Well, [itex]4\mathbb{Z}[/itex] is a subgroup of [itex]\mathbb{Z}_4[/itex] is it not? (Also, this is a normal subrgoup, no?) and [itex]4\mathbb{Z}[/itex] is certainly not a trivial subgroup. So, [itex]\mathbb{Z}_4[/itex] is non-simple because it contains normal subgroups which are not trivial. Suppose that [itex]H[/itex] is a subgroup of [itex]\mathbb{Z}_4[/itex]. H is a retract if there is a homomorphism [itex]p\,:\,\mathbb{Z}_4 \rightarrow H[/itex] such that [itex]p(h) = h[/itex] for all h in H. So do I have to check every subgroup of [itex]\mathbb{Z}_4[/itex] and see if there is a homomorphism? |
| Nov5-06, 10:44 PM | #5 |
There is a canonical map [itex]\phi: \mathbb{Z} \rightarrow \mathbb{Z}_4[/itex], but [itex]\phi(4\mathbb{Z})[/itex] is a trivial subgroup of [itex]\mathbb{Z}_4[/itex]. |
| Nov5-06, 10:52 PM | #6 |
I verified that there is indeed a homomorphism, p, from the group [itex]\mathbb{Z}_4[/itex] into the two trivial subgroups [itex]\mathbb{Z}_4[/itex] and [itex]\{e\}[/itex] satisfying the condition.
| Nov5-06, 10:53 PM | #7 |
Directly. There aren't many subgroups or automorphisms of Z_4 (or of Z_p^n).
| Nov5-06, 11:06 PM | #8 |
{0,1,2,3} {0,2} {0} These are the only subgroups of Z_4 that I could find. Does this look right? |
| Nov5-06, 11:22 PM | #9 |
| Nov5-06, 11:49 PM | #10 |
Well, {0,1,2,3} is a retract since there exists a homomorphism (namely the trivial homomorphism), p, such that p(0)-0, p(1)=1, p(2)=2, p(3)=3 for 0,1,2,3 in the subgroup.
Also, {0} is a retract because the trivial homomorphism p(0) =0. But if [itex]\mathbb{Z}_4[/itex] then {0,2} mustn't be a retract. That means that there must not exist a homomorphism [itex]p\,:\,\mathbb{Z}_4 \rightarrow \{0,2\}[/itex] such that [itex]p(h) = h[/itex] for all h in {0,2}. But surely there is a homomorphism. |
| Nov6-06, 07:27 AM | #11 |
1 generates Z_4. Any homomorphism is completely determined by what it does to the generators. Where can a homomorphism Z_4 -> {your subgroup} map 1?
| Nov6-06, 08:20 PM | #12 |
If it is a homomorphism, must it map 1 to 1? That is, must it map the generator of the group to the same element in the subgroup? But if the subgroup does not have 1, will the homomorphism break down?
| Nov6-06, 09:13 PM | #13 |
| Nov6-06, 09:44 PM | #14 |
Recognitions:
the answer to how did i come up with my answer is: i am teaching abstarct algebra, amnd so i know the classification of abelian groups, and i know that no group of form Z/p^n is a direct sum oif any other pair of groups, as they have different numbers of elements of order p^n.
| Nov7-06, 01:42 AM | #15 |
Wikipedia (which says nothing about homomorphisms having anything to do with the generator) says that a homomorphism is simply a mapping which preserves the identity element. The identity element in [itex]\mathbb{Z}_4[/itex] is 0 mod 4 = {...,-8,-4,0,4,8,...} and the homomorphism h(x) = x which takes an element from [itex]\mathbb{Z}_4[/itex] to the corresponding element in {0,2} is a mapping which preserves the identity: h(0) = 0 which is in {0,2}. So this map is a homomorphism because it preserves the identity. What is wrong with this argument. |
| Nov7-06, 01:47 AM | #16 |
| Nov7-06, 08:13 AM | #17 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Retraction math help
| Retraction/reflection help please | Introductory Physics Homework | 9 | ||
