Solving Mechanics Question: Motorcycle + Rider Masses & Reactions
  • Thread starter Thread starter jimmy p
    Mechanics
The discussion revolves around a mechanics problem involving a motorcycle and rider, specifically focusing on calculating vertical reaction forces at the front and rear wheels under two scenarios: when the rider is present and when he is absent. The problem includes considerations of mass, center of mass, and torque.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of rotational equilibrium and the balancing of torques around a pivot point, specifically the rear wheel. There are attempts to calculate the forces acting on each wheel based on the given masses and distances.
Some participants provide calculations and reasoning for the expected answers, while others express confusion regarding their own calculations. There is acknowledgment of mistakes in unit conversions and assumptions made during the problem-solving process.
Participants note the importance of using the correct gravitational constant and the implications of the motorcycle's center of mass in their calculations. There is also a mention of a diagram that accompanies the problem, which may influence the interpretation of distances involved.
jimmy p
Im doing Mechanics module 2 at college (the only one!) and while working through an exercise i got stumped by this question.
"A motorcycle has a mass of 250kg, and it's rider whose mass is 80kg. The centre of mass of the motorcycle lies on a vertical line midway between its wheels. When the rider is on the motorcycle, his centre of mass is 1m behind the front wheel. Find the vertical reaction forces acting through the front and rear wheels when:
(i) the rider is not on the motorcycle.
(ii) the rider is on the motorcycle."
Then it has a stupid picture of a man on a motobike with the distance 1.4m between the centres of the two wheels (so the centre of mass is as 0.7m)
Now i looked in the back of the book after many failed attempts and the answers are:
(i) 1225N for front wheel, 1225N for rear wheel
(ii) 1449N for front wheel, 1785N for real wheel.
i can't get those answers!
EDIT take gravity as 9.8 instead of 10.
I am assuming you are doing rotational equilibrium, is that right?
So balance the torques: choose the rear (draw it on the left) wheel as the point of rotation. Your clockwise torques are from the bike that is acting at its c-o-m, and the guy on the bike. The only ccw torque is from the front wheel. What force at the front wheel will produce a torque equal to the sum of the other torques?
ps: I get a total cw torque of 2028.6 Nm for the second part.
Well, you certainly ought to be able to get
"(i) 1225N for front wheel, 1225N for rear wheel"!
With the man not on the motorcycle, the weight of the motorcycle, 250kg* 9.8= 2450 Newtons is evenly divided between front and rear wheel: 2450/2= 1225 Newtons.
The man himself has weight 80kg*9.8= 784 Newtons. He is 1 meter from the front wheel so, choosing the front wheel as "center of rotation", his that would be a torque of 784 N-m counter clockwise. That must be offset by the same torque from the force on the rear wheel: its distance from the front wheel is 1.4 m so, taking F as the force on the rear wheel, 1.4F= 784 or F= 784/1.4= 560 N. Of course, the front wheel supports the rest of his weight: 784- 560= 224 Newtons.
Adding in the 1225 Newtons on each wheel due to the motorcycle itself, The front wheel is uspporting 1225+224= 1449 Newtons and the rear wheel 1225+ 560= 1785 N as advertised!
*slaps forehead* Man I am a dumbass, i kept converting mass into Newtons so i was getting 24500! what a loser...
Cheers HallsOfIvy, and thanks for your answer to Chi Meson, maybe i should explain better in future!
  • · Replies 49 ·
13K
9K
  • · Replies 16 ·
20K
