Draw a Triangle on Sphere with Interior Angles > Pi & Sum of Angles = 2pi
  • Thread starter Thread starter UrbanXrisis
    Geometry
The discussion revolves around drawing a triangle on the surface of a sphere, specifically focusing on the properties of the triangle's interior angles, which are stated to be slightly greater than pi, and the total sum of angles equating to 2pi.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the concept of spherical triangles and their angle properties, with some suggesting specific configurations for achieving the desired angle sums. Questions arise regarding the interpretation of the triangle's construction and the terminology used.
The discussion is ongoing, with various interpretations being explored. Some participants have offered potential configurations for the triangle, while others seek clarification on the explanations provided. There is no explicit consensus yet, but the dialogue appears to be productive.
Participants are navigating the complexities of spherical geometry and the implications of angle sums on a curved surface. There may be assumptions regarding the definitions of angles and triangle properties that are under examination.
UrbanXrisis
I need to draw a triangle on a surface of a sphere for which the sum of the interior angles is slightly greather than pi and also the sum of angles is equal to 2pi.
I think i have an idea of what to draw for the sum of interior angles slightly greater than pi (http://www.math.hmc.edu/funfacts/ffiles/20001.2.shtml) , but not quite sure how to get the angles greater than 2pi
any ideas?
well if you want slightly larger than pi, any non-zero area triangle on the surface of the sphere will work. For exactly 2pi, try going from north pole to equator, then around on the equator to direct opposite side, then back up to the north pole. Go farther than direct opposite side if you want more than 2pi. Hope this helps and you can visualize what I'm saying.
it is a bit difficult, could you give another explanation?
what do you mean by "from north pole to equator"?
thanks
it means you dessend along a meridian.
The "triangle" dimachka is talking about is 1/4th of the surface of the sphere.
It has half the equator as one of its side and its other side passes through the north pole.
  • · Replies 29 ·
