How is non-uniaxial strain defined?
  • Thread starter Thread starter scott_alexsk
    Strain
The discussion centers around the definition of non-uniaxial strain, particularly in the context of Nitinol and its maximum strain before failure. Participants explore how to quantify bending strain in relation to the known 8% strain limit and the implications of bending versus uniaxial stretching.
  • Some participants suggest looking into strain tensors to better understand non-uniaxial strain.
  • There is a discussion about the relationship between bending and strain, with some noting that bending may not be adequately covered in typical strain definitions.
  • One participant mentions that laboratory tests are necessary to establish the relationship between stress and strain in bending scenarios.
  • Flexural strain is defined as the strain in the outer surface of a bent wire, which is under tension.
  • Another participant raises the point that the 8% strain is associated with plastic deformation rather than failure, and questions how this relates to the yield strength of 70 MPa.
  • There is confusion about whether the 8% strain and 70 MPa yield strength are interchangeable in different modes of strain (tensile vs. flexural).
  • Participants discuss the calculation of strain in curved materials and the need for specific geometry to determine the relationship between bending and strain.
  • One participant clarifies that strain is a unitless ratio, confirming that 8% strain is represented as 0.08.
  • There are inquiries about sources for the theory of elasticity, with some expressing dissatisfaction with existing literature on the topic.
Participants express varying views on the definitions and relationships between bending strain and uniaxial strain. There is no consensus on how to define or calculate non-uniaxial strain, and multiple competing perspectives remain throughout the discussion.
Participants note that definitions may depend on specific conditions and geometries, and there are unresolved aspects regarding the application of strain concepts to bending versus uniaxial loading.
scott_alexsk
Hello,
How is non-uniaxial strain defined? How would Nitinol's 8% maximum strain before failure be defined as in terms of other than stretch? How does one define the 8% in terms of bending the wire? So in other words how much bending of the wire equates to an 8% strain limit?
Thanks,
-scott
I know I'm not sounding very specific, but you may want to look at strain tensors.
Just, looking at that right now on Wikipedia, it does not seem to concern bending as a type of strain, just shear strain and uniaxial strain distortions.
-scott
Well, you'd need some laboratory tests to get the relation between stress and strain in the case of bending.
When a material bends, the outer curved suface is in tension and the inner curved suface is in compression. There is a neutral position between those two surfaces where there is no stress. For most materials the compressive strength is greater than the tensile strength. Therefore most bent materials fail in tension. Bending failure ususally occurs where tensile force is greatest. Stress-raisers, such as surface defects, can cause up to a three fold increase in stress.
Failure in shear is less common, but that is what makes cutting operations possible. Failure in torsion is often a a shear failure.
The measurement of stresses, the design of structures, and the analysis of their failures are the subjects included in courses on the mechanics of materials.
I hope this points you in the right direction.
scott_alexsk said:
Hello,
Thanks,
-scott
Flexural strain is defined (typically) as the strain in the outer (convex) surface, the surface which is under tension (for the reason stated by drachir, above).
Note: You can estimate the curvature that makes an 8% strain from the cross-sectional geometry and making the neutral axis lie along the cetroidal axis of the wire.
If you tell us the geometry of your wire, someone here can show you how to do the calculation.
The length of my wire is 25 cm and its diameter is 0.3175 cm. The 8 percent strain is actually not the point at which the Nitinol wire fails but the point that the wire is plastically deformed. I have also seen the point of plastic deformation written as 70 MPa. Does this basically mean that 70 MPa will create an 8% strain in most cases?
I am going to be measuring the force differently treated samples of nitinol can pull with. The key is that I do not get above 70 MPa's pulling from the spring balance, so that the wire is not plastically deformed. The spring balance is measured in Newtons. How can I convert the 70 MPa's into Newtons pulling uniaxially on the sample of Nitinol wire previously described?
Thanks,
-scott
This is confusing! Are you looking at two different modes (i) flexure (bending), and (ii) tension (stretching) ?
If you want to use the nitinol to "pull", then you are interested in tensile failure (yield point in tension). To convert from force in N to uniaxial stress in Pa, simply divide the force by the relevant area in sq. meters. A MPa is just 10^6 Pa. For tensile (stretching) loads, the area of interest is the cross-sectional area of the wire.
PS: If 70MPa and 8% are the yield point and the strain at yield for the exact same alloy, then yes, the one produces the other (though only accurately when you have the same conditions as those for which the numbers are specified).
So the relevant area is simply the area is square meters of the single cross section?
Sorry for being confusing, I am testing a lot of different things. Yes I am looking at two different modes. (I had a feeling I should not have posted that second set of questions) For one I am going to see what kind of force a straight annealed wire, strained less than 8%, will pull with.
After that I intend to see what force a wire annealed in a curve will pull with. Using the information I find on calculating strains with bent materials, hopefully I can calculate what force from the spring will provide slightly less than an 8% strain for that sample also.
Finally I hope to test what force another sample, trained with the two way memory effect, can pull with, also being strained less than the critical 8% (although testing this one will be messy.) The information I am asking about strain with curves most particularly applies to this third test, because when training the alloy for the two way memory effect it is critical when training to exceed the 8% strain.
I have seen the two phrases of 8% strain and 70 MPa used interchangably to represent the point of plastic deformation and the point at which the memory properties are degraded. However looking on the fact sheet, 70 MPa is defined as the Yield Strength.
Is it only when the wire is being uniaxially strained do the 8% and the 70 MPa equate? Otherwise when dealing with strain with curved surfaces do I simply go with the 8% strain for determining the point of plastic deformation?
Thanks,
-scott
So does anyone know how to find the strain of a curve or know where it might be discussed?
Thanks,
-scott
Thanks,
-scott
There's no such thing as "strain of a curve", so it's not clear what you're asking. Do you mean strain in flexure (bending)? Or are you simply talking about tensile strain in a curved (and constrained) wire?
Is the applied force trying to bend/unbend the wire or is it trying to stretch a wire bent around something?
http://www.diracdelta.co.uk/science/source/f/l/flexure mode/image001.jpg <figure on left is flexure>
http://kosmoi.com/Science/Physics/Machines/pulley.gif <rope bent around pulley is in tension>
I am referring to flexural strain.
-scott
Let the angle (in radians) subtended at the center be [itex]\theta[/itex], when the strain is [itex]\epsilon[/itex]. The length of the wire is L and its radius is r. Then, [itex]\theta = \epsilon L /r[/itex].
Thanks Gokul, but what unit is strain in? Is it percent lenght? Would 8% strain be 0.08, 1.08, 108, 8? I assume it is 0.08 but I am not sure.
-scott
Yup, that's the right one. It's a unitless ratio.
Thanks again. I get a pretty big number from that but from what I have seen, it seems true.
-scott
Sources for theory of elasticity?
Sigh... I complained long ago in WP talk pages that the articles on elasticity tended to be unreadable, disorganized, featured messy and uneven coverage of possible topics, and so on. The principle author took this well (the subject wasn't his thing, he was just trying to fill a gap in WP as best he could) and invited me to contribute improvements, but I never had time and eventually stopped editing the WP entirely (long story). I haven't had the heart to take a look to see if there has been any improvement.
Anyway, I'd advise that in general, WP should never be your only source for anything important, that you bear in mind that anyone can edit the WP (with all the consquences that implies for the instability and questionable reliability of this "encyclopedia"), and that you move on to real textbooks published by reputable publishers as quickly as possible.
Alas, in this particular area I don't know of any books which do a really good job of explaining the fundamental ideas of the theory of elasticity in a reasonably brief space in a way suitable for contemporary students. Landau and Lifschitz, Theory of Elasticity, Vol. 7 in their Course of Theoretical Physics, Pergamon, 1986, might be your best choice, if you can find it. If your interest comes from physics rather than engineering, which seems not be the case here... If you read between the lines and can handle a somewhat idiosyncratic notation, Jeffreys and Jeffreys, Methods of Mathematical Physics, 3rd Ed., Cambridge University Press, 1972, offer a very brief overview. I'd be happy to hear recommendations from others! Gokul?
Chris,
L&L v7 is, as you've pointed out, aimed at the physicist, rather than the engineer. And even by the standards of L&L, I believe this one sets the record for brevity, or if you wish, succinctness. It took me many times as long to digest one page from that text, as I'd spend on a page from most other texts. But all this is based on no more, sadly, than the most fleeting relationship with this book.
I was raised on Timoshenko (which is aimed at engineers - and will likely serve as a good reference to the OP) and would recommend most any of his books on the mechanics of solids.
https://www.amazon.com/s/103-396551...exact=Timoshenko, Stephen P&tag=pfamazon01-20.
9K
