RLC Circuit with damping questions
The discussion centers on determining the initial current (I[SIZE="1"]0) in an RLC circuit after conducting experiments that resulted in overdamping, underdamping, and critical damping. The user seeks to solve three differential equations to create a predicted results graph but lacks current measurements. It is established that using Kirchhoff's law, one can calculate the initial current if the resistance values and voltage are known, although discrepancies between calculated and measured values may arise due to uncertainties.
  • Understanding of RLC circuit dynamics
  • Familiarity with Kirchhoff's laws
  • Knowledge of differential equations
  • Experience with circuit measurement techniques
  • Study Kirchhoff's voltage and current laws in depth
  • Learn how to solve differential equations specific to RLC circuits
  • Research methods for measuring current in circuit experiments
  • Explore the effects of damping in RLC circuits
Electrical engineers, physics students, and anyone involved in circuit design and analysis, particularly those studying RLC circuit behavior and measurement techniques.
totallydesperate
I have an RLC Circuit. I've changed the resistors 3 times to give me a case of overdamping, underdamping, and critical damping. In taking my data (this was a long long time ago) I apparently missed taking measurements of current. I'm trying to solve the three differential equations to make a "predicted results" graph. To do this, I need initial conditions V0, which I have, and I0, which I should have. Is there any way besides redoing my experiment to determine what the current at t=0 would be? If so, what other information do you need from me to explain it to me?
If you know the value of the resistances and the voltage, then technically you should be able to calculate the current using the Kirchoff law. Even so, keep in mind that calculated values are often a bit different from measured values due to uncertainties. If you're using a calculated value for current when you were supposed to use a measured one, it kind of misses the point.
  • · Replies 21 ·
