Solving a Simple ODE from the Navier-Stokes
  • Thread starter Thread starter Peregrine
    Navier-stokes Ode
The discussion revolves around solving a simplified ordinary differential equation (ODE) derived from the Navier-Stokes equations, specifically related to fluid flow. The original poster attempts to find a solution for the velocity component Vz in a radial flow context.
  • Participants explore different methods to solve the ODE, including assuming a power law solution and later substituting derivatives with a new function. Questions arise regarding the physical implications of the solutions obtained, particularly concerning the expected radial profile of the velocity.
Multiple approaches have been proposed, including the use of exponential functions and hints for substitution. Participants are actively questioning the validity of their methodologies and the physical relevance of the solutions they derive, indicating a productive exploration of the problem.
There is an ongoing discussion about the assumptions made in the problem setup, particularly regarding the expected behavior of the flow and the implications of the derived solutions. Participants are also considering boundary conditions that may affect the final form of the solution.
Peregrine
I've reduced a portion of the Navier Stokes to solve a flow problem, and am left with the following ODE:
[tex]u (\frac {\partial^2 Vz} {\partial^2 r}) + \frac {r} {u}\frac {\partial Vz} {\partial r} = 0[/tex]
I tried to solve this equation by assuming a power law solution with
[tex]Vz = Cr^n[/tex]
Which yields
[tex]n(n-1)r^{n-2} + nr^{n-2} = 0[/tex],
Thus n^2 - n + n = 0
Which seems to indicate [tex]n^2 =0[/tex] => n = 0
So Vz = C. But, I don't think this is what physically happens, Iam expecting a radial profile and not a flat profile, so I'm looking for where I took a wrong turn. Any ideas? Thanks.
HINT: Substitute [itex]\frac{\partial V_{z}}{\partial r}[/itex] by a new function, let's call it [itex]f(r,...)[/itex]. Then see what you get.
Daniel.
So, using the hint I get:
uf''(r) + (u/r)f'(r) = 0
Assuming an exponential function,
[tex]f(r) = e^{nr}[/tex]
[tex]f'(r) = ne^{nr}[/tex]
[tex]f''(r) = n^2e^{nr}[/tex]
Thus
[tex]un^2e^{rn} + (u/r)ne^{rn} = 0[/tex]
[tex]u(n^2+1/rn) = 0[/tex]
[tex]un(n+1/r) = 0[/tex]
[tex]n = 0, -1/r[/tex]
So:
[tex]Vz = Ae^{0} + Be^{-1/r}[/tex]
Is that the correct methodology? Thanks again.
I get the eq for "f"
[tex]u\frac{df}{dr}+\frac{r}{u}f=0[/tex]
with the solution
[tex]f(r)=Ce^{-\frac{r^{2}}{2u^{2}}}[/tex]
and then finally
[tex]V(r,\vartheta)=C\int Ce^{-\frac{r^{2}}{2u^{2}}} \ dr + g(\vartheta)[/tex]
The integral brings in the erf function, while the angle dependence should be determined by boundary conditions.
Daniel.
  • · Replies 0 ·
