Rate of change, derivatives problem .
The discussion revolves around a problem related to the rate of change and derivatives, specifically focusing on smoking rates among Canadians aged 15 to 19. Participants are examining a table that presents percentage data and are tasked with answering related questions.
  • Participants discuss graphing the data and using linear approximations to analyze the rate of change. There are attempts to clarify the nature of the data presented in the table and how to calculate the rate of change from the percentages given.
Some participants have provided guidance on how to approach the problem, suggesting methods like linear approximation and regression analysis. There is an ongoing exploration of the correct interpretation of the data, with multiple interpretations being discussed without a clear consensus.
Participants note that the original poster may have misunderstood the data, which is presented as percentages rather than direct rates of change. There is also a mention of needing to calculate the rate of change for both males and females, with some uncertainty about the process involved.
manik
rate of change, derivatives problem...
This table shows the rate of change Canadians who are between 15 and 19 and who smoke...
http://img155.imageshack.us/img155/8915/asdce2.jpg
please answer the questions below it.. thanks in advance
if you want people to help, you are going to have to show what you have tried so far... have you tried graphing the data and using linear approximations?
i tried graphing it on a TI-84, and found the regression and its a cubic equation i think..
i mean if someone can possibly get me started or something i would appreciate it as i am unsure how to find the rate of change for male and female
with a table of data, the best you are going to do without using regression is to approximate linearly between any two points and use that as an approximation to the rate of change in that two year period. Doing that, you can answer the two questions given to you.
can u do 1 for me (like male) just to see what you mean.. then i should be able to do the female..
can anyoen guide me please
First, state your problem correctly! That table is obviously not the "rate of change of Canadians who are between 15 and 19 and who smoke" it is the percentage of such Canadians who smoke. You need to calculate the rate of change yourself. Since the change in time is just one year you need only subtract each years percentage from the next years percentage. In what year do you get the same answer for both males and females? Is the final rate of change positive or negative?
21K
  • · Replies 18 ·
