Thread Closed
Distance under constant acceleration
Share Thread Thread Tools
Nov6-06, 06:24 AM   #1
A body starts from rest with an acceleration of 11m/s².
What is it's velocity after 6 seconds. (I got 66 for that) and how far did it travel?
What forumla do I have to use for this?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Nov6-06, 06:43 AM   #2
Recognitions:
Homework Helper Homework Help
There is a well-known expression which represents displacement under constant acceleration. Try to find it. (Either here or google it up.)
Nov6-06, 06:54 AM   #3
Is displacement the same as distance?
Nov6-06, 06:56 AM   #4
Recognitions:
Quote by Alpha[X]²
Yes it is, in this case.
Nov6-06, 07:01 AM   #5
What about the first part of the question?
I tried to average out the velocity and then using the d=vt formula I got 198m.
Nov6-06, 07:11 AM   #6
Quote by Alpha[X]²
Yes, you did it correctly. Remember that you could calculate the displacement averaging out the velocity only because the acceleration is constant.
The other formula would be: d = (1/2)at2. Check that the solution is the same.
Try to show that v(average)*t = (1/2)at2
Thread Closed
Thread Tools
Similar Threads for: Distance under constant acceleration
Thread Forum Replies
Final velocity of an object accelerated across a given distance with constant power Introductory Physics Homework 9
time as a function of distance for constant a Special & General Relativity 18
Two masses connected by constant distance Classical Physics 3
Acceleration Distance General Physics 7
constant velocity or at constant acceleration General Physics 3
