Understanding intake manifold principles.
  • Thread starter Thread starter Bret Williamson
    Manifold
The discussion focuses on the principles of intake manifold designs for early Ford 4-cylinder engines, specifically the T-, A-, and B- engines. Participants explore the configurations of dual-carburettor manifolds, including the use of cross-over pipes and their effects on performance and synchronization of carburettors.
  • One participant inquires about the theory behind cross-over pipes in intake manifolds and whether one design is more effective than another.
  • Another participant suggests that the cross-over pipe serves to balance pressure in the intake runners, ensuring equal induction of air-fuel mixture across cylinders.
  • A different participant shares experiences with separate plenum systems and suggests that the cross-over may help reduce synchronization issues with carburettors.
  • One participant describes their own experience with a Ford engine that uses twin-choke carburettors and notes the challenges of balancing the pairs of cylinders compared to a single carburettor setup.
  • Another participant recalls reading about the balancing effects of crossover pipes in exhaust systems, indicating a potential parallel in intake manifold design.
  • A participant expresses intent to build a dual-carb manifold while seeking to understand the underlying principles to avoid unnecessary design complications.
  • There is a light-hearted suggestion about using twin choke Weber DCOE carburettors in the design.
Participants express various viewpoints on the function and effectiveness of cross-over pipes in intake manifold designs, with no consensus reached on the superiority of one approach over another. The discussion remains open to differing interpretations and experiences.
Participants reference historical designs and the evolution of carburettor technology, indicating that the effectiveness of different manifold designs may depend on specific configurations and the era of components used.
Individuals interested in automotive engineering, particularly those focused on vintage engine designs and intake manifold configurations, may find this discussion relevant.
Bret Williamson
Hi there, hope someone is able to help me. I am trying to find some info on early intake manifold designs, for Ford 4 cylinder engines, otherwise known as the T-, A- and B- engines. These engines came standard with two intake manifold inlets, and 4 exhaust manifold outlets cast into the block.
I have found lots of pictures of after-market dual-carburettor manifolds. These used dual intake runners, with two general systems. In the first system, the carburettors mounted on a common plenum, which then opened into the intake runners. In the second system, the carburettors were mounted at the top of the intake runner, with a cross-over pipe linking the intake runners.
Does anyone know the theory behind this cross-over pipe, or seeming balancing of the intake runners? Is one more effective than the other? Can anyone point me to a source that might explain the principles?
Cheers
Bret W.
Sounds like it's just a balancing pipe, equalising pressure in the runners to ensure that the cylinders are inducing the same quantity, and mixture, of inlet charge.
Do you have any pictures of the arrangements?
Don't know the Ford engines, but I've dealt with separate plenum systems on other engines.
It was a real headache to syncronize the carbs.
Perhaps the crossover was intended to reduce the syncronization problem as brewnog suggests.
I've got a Ford engine (1960s design) using two twin-choke carbs, so there is a plenum for each pair of cylinders. As a result, cylinders 1 & 2, and cylinders 3 & 4 are balanced, but it can be quite a pain to balance the two pairs. The original carburettor on the engine had a single plenum, and single carb feeding all four cylinders on a common manifold. Much easier to set up, but not nearly the same flow.
I think you are on to something there brewnog. I seem to remember reading something similar about crossover pipes in exhaust systems blancing the pressure.
I am planning to build a dual-carb manifold, but thought i would try to understand the principles before i added anything to the design unnecessarily! Like i said, a lot of the aftermarket stuff was twin-carb items, most developed in the 30's, 40's and 50's, when there wasn't a wide range of different flow-rate carbs to choose from, like we have today. So, those clever guys realising that the more air/fuel mix available, the more potential energy, started adding multiple carbs.
So, my aim is to emulate that basic idea, but using more modern (60's) carburettors.
Mmm, twin choke Weber DCOEs maybe?
:smile:
17K
9K
11K
60K
  • · Replies 48 ·
23K
