B&W Glass Filter: Does it Exist?
  • Context: High School
  • Thread starter Thread starter eyedreamer
    Filter Glass
The discussion centers around the existence and feasibility of a black-and-white (B&W) glass filter that could generate a B&W image without the use of a camera or computer. Participants explore theoretical possibilities, practical limitations, and alternative methods related to optics and image processing.
  • One participant inquires about the existence of a B&W glass filter, noting the limitations of monochromators which act on single rays.
  • Some participants argue that since white light contains all wavelengths, filtering out colors would prevent the existence of a true B&W filter.
  • Another participant suggests that equal values for red, green, and blue (RGB) could theoretically produce a grayish color, but questions the practicality of this in the physical world.
  • One participant proposes using side-by-side red, green, and blue filters to create a B&W image, but others challenge the feasibility of this approach.
  • Concerns are raised that using multiple filters would not yield a grayscale output, as each filter would only allow its respective color to pass through.
  • Some participants discuss the need for a device that could transform specific frequencies into a uniform distribution across the visible spectrum, suggesting a "multichromator" as a theoretical solution.
  • There are mentions of active solutions, such as using certain materials that can upconvert or downconvert light frequencies, but these require power and are not purely passive optics.
  • Participants express uncertainty about the technical aspects and limitations of achieving a B&W representation without electronic devices.
Participants generally do not reach a consensus on the feasibility of a B&W glass filter. Multiple competing views remain regarding the methods and principles involved in creating a B&W image using optical filters.
The discussion highlights limitations related to passive optics and the necessity for active solutions to achieve the desired outcome. There are unresolved questions about the specific materials and technologies that could potentially facilitate this process.
eyedreamer
Hi to all!
I have a little question for you. Does a b&w glass filter exist?
I now there are all kind of color glass filters, but I want to know if there are any possibilities to generate a b&w image without using your camera or your computer.
I know about the monochromator device, but it acts on a single ray. I'm not sure if I could get an image using a monochromator.
Any help would be appreciated!
Science news on Phys.org
Not that I know of, no.
- Warren
The problem that I can see here is that white light is composed of all wavelengths. As soon as you start filtering out colours, it can't exist.
What if it is somehow possible to get equal value for R, G and B? I'm not sure whether this works in the real physical world, but I know that a color with a value RGB 50/50/50 (or simply said x/x/x) is a greyish color.
Well, a "black-and-white filter" maps a color (R, G, B) to a colorless triple like (R+G+B, R+G+B, R+G+B). This filter involves adding frequencies together, which physical filters cannot do. All that a physical filter can do is remove frequencies from its input.
- Warren
I just had me a thought here, but I don't know if it would work.
Take one R filter, one G, and one B. Mount them side-by-side, then use lenses to correct for parallax and focus them all on one viewing area.
Chroot...?
Danger, I had a similar idea, too. But chroot said that a physical filter only removes frequencies from its input. I think that this will produce a totally white image. Am I right or...?
I was actually imagining as if the picture passing thorugh a monochromator, it separates the different colors, and then they're somehow equalized to the same value, thus producing a b&w image. Correct me if this doesn't make any sense :)
I'm going to wait for Chroot or someone else about this. I'm over my head.
I think the 3-color filters method is how they capture images on spacecraft and the Mars rovers... Combined they give you a full color picture.
You can capture a black & white picture on B&W film, btw.
Mech_Engineer, a b&w film works different. The film has some kind of grains on it, which are light-sensitive. As soon as the lighting strikes over them, they can't "reset" anymore. I want to be able to see through those filters or whatever it is, and see a b&w representation. I don't need a still image. Hope you understood me. Thanx for the tip, btw.
Chroot, What do you think about Danger's preposition?
Danger's idea would not work.
Imagine that the image you want to pass through your filter has only the color red in it. Your desire a filter that produces a grayscaleB] output. In other words, dim red light would appear on the output screen as dim white light; bright red light would appear on the output screen as bright white light.
Assume that you pass your red image through Danger's three-filter system. The red light would go through the red filter, but will be blocked by the green and blue filters next to it. The final image formed will be... red. Not white.
- Warren
Warren, I think that I might not have expressed my intention properly, given your response. The filters that I proposed are beside each other, not in line. Lenses compensate for the parallax difference, so that each one 'sees' the same image despite their spatial orientation. You then have one red image, one green image, and one blue image all coinciding at the same viewing pane. It still might not work, but not for the reason that you cited.
Danger,
I understood your proposal perfectly well. You didn't understand my response.
For example, the desired "black and white filter" would convert an image containing nothing but shades of red into shades of gray, based on their intensity. Your filter setup could not do this. If you pass red light through your side-by-side red, green, and blue filters, you will get a red image on the other end.
- Warren
Indeed, what it would need here is the opposite of a filter: a device that trasforms the energy of a specific frequency into the same energy equally distributed on the entire visible spectrum; instead of a "monochromator", a "multichromator"!
Are there optical crystals which can have a similar property or, at least, which can broden the spectrum's range of a light source?
So, you mean that you could simply need a B&W videocamera?
I'm going to have to bail out of this one, guys. It seems to be something that I know so little about that I can't even quite follow the explanations. I'll keep reading to learn more, though.
Meanwhile, how about a night-vision device or a simple B&W TV camera?
Chroot, you said that the filter should be able to add frequencies together. Is there any physical way to accomplish this? For example to separate the image on 3 channels and then add their frequencies together?
Danger: My initial plan was to create a mirror which will reflect a B&W image, instead of color. But I would be happy ig I could make a simple B&W image without using any electrical stuff.
eyedreamer:
There is absolutely no way to do this with passive optics. If you pass in an image with nothing but shades of red, you want to get out an image with nothing but shades of gray. To convert red into gray, you have to add additional blue and green light. No mirror or lens can do this. You're stuck with some kind of active solution.
- Warren
Certain types of material can up convert or down convert the frequency of the incident light.
Theoretically, if the right materials were actually available, you should be able to create a solid state device to do this.
I would consider this to be an active solution, just as chroot says.
Any idea what kind of materials should I use?
Once you bring in power supplies, there are about a million ways you could accomplish this B&W "filter" -- but there's no way to make it using nothing but passive glass and mirrors.
- Warren
Gonna have to wait for nanotech to get a bit farther along :smile:
In the meantime, you can use your computer to recolor video anyway you want.
9K
  • · Replies 24 ·
  • · Replies 20 ·
  • · Replies 40 ·
  • · Replies 17 ·
