Question involving LAWS OF WORK
  • Thread starter Thread starter demode
    Laws Work
The discussion revolves around calculating the mechanical advantage and work done using a pulley system to lift a 1000-N crate. In an ideal machine, the effort required to lift the crate is 250 N, derived from the equation 1000 N * 5.0 m = X N * 20.0 m. The actual effort applied is 300 N, indicating that 50 N is used to overcome friction. The work output is calculated as 5000 J (1000 N * 5.0 m), while the work input, using the actual force, is 6000 J (300 N * 20.0 m). The ideal mechanical advantage (MA) is 4, and the actual MA needs to be calculated based on the actual effort.
  • Understanding of basic physics concepts such as work, force, and mechanical advantage.
  • Familiarity with the equations for work output and input.
  • Knowledge of friction and its impact on mechanical systems.
  • Ability to solve algebraic equations related to force and distance.
  • Learn about the principles of mechanical advantage in simple machines.
  • Study the effects of friction on work and energy in mechanical systems.
  • Explore the differences between ideal and actual mechanical advantage.
  • Investigate the calculations involved in work-energy principles in physics.
Students studying physics, engineers working with mechanical systems, and anyone interested in understanding the dynamics of pulleys and work calculations.
demode
I have been given the prompt:
"Using a set of pulleys, a mover raises a 1000-N crate a distance of 5.00 m. This is accomplished by pulling in 20.0 m of cord"
I need to find
  • How much effort would have to be applied if this were an ideal machine
  • If the effort actually applied is 300 N, what force is used to overcome friction?
  • What is the work output?
  • What is the work input?
  • What is the real mechanical advantage?
I don't know if I have done this correctly so if someone would be willing to verify my answers or guide me through this, it would be appreciated.
1. In an ideal machine, I believe work input is equal to work output. With that being said, I can set up the equation 1000N * 5.0 M = XN * 20.0 M, then I can solve X for 250 N... Correct?
2. I'm not too sure what it means when it asks to OVERCOME friction, so what do i do?
3. Work output is just equal to force * distance, so we evaluate the given 1000N force times the given 5.0 M distance and get 5000 J, Correct?
4. Work input is just equal to force * distance as well, so we evaluate the value we solved for in number 1 (250) and multiply by the given 25 m distance and get 5000J, correct?
5. Not sure at all what to do :confused:
I need to find
1. In an ideal machine, I believe work input is equal to work output. With that being said, I can set up the equation 1000N * 5.0 M = XN * 20.0 M, then I can solve X for 250 N... Correct?yes[/color]
2. I'm not too sure what it means when it asks to OVERCOME friction, so what do i do?Idealy it would take 250N of force, but it took 300N. So why was the extra 50N required?[/color]
3. Work output is just equal to force * distance, so we evaluate the given 1000N force times the given 5.0 M distance and get 5000 J, Correct?yes[/color]
4. Work input is just equal to force * distance as well, so we evaluate the value we solved for in number 1 (250) the problem wants you to use 300N here, not the ideal 250N[/color] and multiply by the given 25 m you mean 20m[/color]distance and get 5000J, correct?that works out to 6000J[/color]
5. Ideal MA is 4, since it took just 1/4 of the weight to move it (250/1000 =1/4). So its actual MA is??[/color]
alright man, I understand it. Thanks SO much
  • · Replies 58 ·
  • · Replies 21 ·
