Is There Evidence for the Existence of Torque in a Stationary System?
  • Thread starter Thread starter Phil7860
    Torque
The discussion centers on proving that the sum of torque in a stationary (non-rotating) system equals zero. A meter stick with evenly distributed mass is used as a practical example, demonstrating that when balanced on a fulcrum, the torques on either side must counteract each other to maintain equilibrium. The conversation emphasizes that any displacement from this balance will result in rotation, reinforcing the principle that torque sums to zero when the system is stationary.
  • Understanding of basic physics concepts, particularly torque and equilibrium.
  • Familiarity with the principles of levers and fulcrums.
  • Knowledge of mass distribution and its effects on balance.
  • Basic experience with experimental physics and practical demonstrations.
  • Research the mathematical formulation of torque in static systems.
  • Explore the principles of rotational dynamics and their applications.
  • Learn about the conditions for static equilibrium in physics.
  • Investigate real-world applications of torque in engineering and mechanics.
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of torque and equilibrium in stationary systems.
Phil7860
Okay, so the problem is pretty simple:
Prove that in a stationary (non-rotating) system, that the sum of the torque equals zero.
My solution is to take a meter stick that's mass is evenly distributed. Find the center of the meter stick, then balance it on a fulcrum point. Since the object is not rotating, the sum of the torques must equal zero.
Move the meter stick to the left or right, and the stick will rotate counter/clockwise.
My question is, would that convince you that the sum of the torque equals zero in a stationary system?
move it so it's off balance then put a light weight on the far, long end; and put a heavier weight on the shorter end wherever appropriate to make the thing balance.
  • · Replies 17 ·
  • · Replies 28 ·
