Solving Stearic Acid Problems - Questions & Answers
  • Thread starter Thread starter max1205
    Acid
The discussion focuses on calculating the mass and volume of stearic acid in a solution. The initial problem involves a 0.01 mL solution containing 2 grams per liter of stearic acid, resulting in a mass of 2 x 10^-5 grams. The second part addresses the volume of stearic acid after evaporating acetone, yielding a volume of 2 x 10^-8 liters based on the density of stearic acid at 0.9408 g/mL. The solutions provided are confirmed to be correct by other participants in the forum.
  • Understanding of molarity and mass concentration
  • Knowledge of density calculations
  • Familiarity with unit conversions (mL to L)
  • Basic chemistry principles related to solutions
  • Study the concept of molarity and its applications in solution chemistry
  • Learn about density and its role in calculating mass and volume
  • Explore unit conversion techniques for accurate measurements
  • Investigate the properties and applications of stearic acid in various chemical contexts
Chemistry students, laboratory technicians, and anyone involved in solution preparation and analysis will benefit from this discussion.
max1205
Hi,
I have two questions that I am stuck on involving stearic acid solutions.
1a) 0.01mL of a solution containing 2 grams per litre of stearic acid in acetone is used. What mass of stearic acid is present in this drop of solution?
Solution:
0.01ML solution X (1L/1000mL solution) X 2g stearic acid/1L solution
= 2 x 10^-5 g
1b)The density of stearic acid is 0.9408g/mL. What will be the volume of stearic acid left from the drop of solution when all the acetone is evaporated?
Solution:
.00002g stearic acid X (1mL/0.9408g stearic acid) X (1L/1000mL)
= 2 x 10^-8 L
These are the best solutions I could come up with but I have a feeling both are incorrect. Any help would be appreciated.
thank you.
max1205 said:
Hi,
Solution:
= 2 x 10^-5 g
Solution:
= 2 x 10^-8 L
thank you.
Both look fine.
Thank You!
40K
