Which Factors Determine the Rate of SN1 and SN2 Reactions?
  • Thread starter Thread starter Soaring Crane
    Substitution
The discussion focuses on the factors influencing the rates of SN1 and SN2 reactions, specifically comparing 1-chlorobutane, 1-bromobutane, and 2-chlorobutane in NaI with acetone as a solvent. The consensus is that 1-bromobutane reacts the fastest due to the larger bromine atom, followed by 1-chlorobutane, while 2-chlorobutane, being a secondary substrate, reacts the slowest. Additionally, the participants confirm that tertiary alcohols and carbocation intermediates are characteristic of SN1 reactions, while inversion and retention of stereochemistry are indicative of SN2 reactions.
  • Understanding of SN1 and SN2 reaction mechanisms
  • Knowledge of nucleophiles and their effects on reaction rates
  • Familiarity with organic solvents, specifically acetone
  • Basic concepts of carbocation stability and substrate types (primary, secondary, tertiary)
  • Study the differences between SN1 and SN2 mechanisms in detail
  • Research the role of solvent polarity in nucleophilic substitution reactions
  • Explore the concept of carbocation stability and its impact on reaction rates
  • Examine experimental methods for measuring reaction rates in organic chemistry
Organic chemistry students, researchers in chemical kinetics, and educators teaching nucleophilic substitution reactions will benefit from this discussion.
Soaring Crane
1) Predict the relative reaction times from fastest to slowest for the following compounds with NaI in acetone: 1-chlorobutane, 1-bromobutane, 2-chlorobutane.
I am assuming that this is under SN2 reaction conditions with the solvent and compound given.
2-chlorobutane = secondary substrate = slowest
1-bromobutane = primary substrate = fastest (Br is larger than Cl)
1-chlorobutane = primary substrate = moderate rate
2) Indicate whether the following statements refer to SN1 or SN2 reactions.
tertiary alcohols - SN1??
sp2 planar like transition state - SN1?? I am unsure of this one.
reaction rate independent of the concentration and nature of nucleophile = SN1??
inversion and retention of stereochemistry - SN2??
primary and secondary alcohols - SN2?
carbocation intermediate - SN1 ??
Thanks.
You are correct in your assumptions. I performed a similar experiment just yesterday for my organic lab.
28K
10K
