Thread Closed
kinematics equation problem
Share Thread Thread Tools
Nov9-06, 11:44 PM   #1
"An experimental rocket sled can be accelerated at a constant rate from rest to 1600 km/hr in 1.8 s. What is the magnitude of the required net force if the sled has a mass of 500 kg?"
I know I have to use
[sum of the] F = ma
and i was trying
= 500 x 1600,
but I'm sure there's something else I have to do to get the right answer, since this isn't working..
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Nov10-06, 12:21 AM   #2
Recognitions:
Homework Helper Homework Help
Look again at the definition of acceleration. You have used velocity in place of acceleration. Be careful with your units. km/hr is not m/s.
Nov10-06, 12:36 AM   #3
If you are having trouble, try solving it in terms of kinematics first. After you find the acceleration, then you can do what you did.
Thread Closed
Thread Tools
Similar Threads for: kinematics equation problem
Thread Forum Replies
Kinematics question - which equation to use? Introductory Physics Homework 2
Equation of Kinematics for Constant Acceleration Introductory Physics Homework 3
Time Independent Rotational Kinematics equation??? General Physics 1
Position Loop Equation (Kinematics) Mechanical Engineering 2
