Liquid seperation of B-carotene and Chlorophyll-a
  • Thread starter Thread starter dibilo
    Liquid
The discussion centers on the liquid separation of B-carotene and Chlorophyll-a, analyzed using a UV spectrometer. B-carotene exhibited peaks at 448nm and 475.1nm, while Chlorophyll-a showed peaks at 417.9nm and 666.1nm. The presence of two peaks for each compound is normal and can be attributed to the conjugated nature of these molecules, as well as potential impurities. The close proximity of B-carotene's peaks indicates poor resolution, which is a common occurrence in such analyses.
  • Understanding of UV-Vis spectroscopy principles
  • Familiarity with B-carotene and Chlorophyll-a molecular structures
  • Knowledge of color theory in relation to absorption spectra
  • Basic grasp of the particle in a box model in quantum mechanics
  • Research UV-Vis spectroscopy techniques and best practices
  • Study the molecular structure and properties of conjugated organic molecules
  • Explore the particle in a box model for understanding electronic transitions
  • Learn about methods for improving resolution in spectroscopic measurements
Chemists, biochemists, and laboratory technicians involved in spectroscopic analysis and those interested in the properties of organic compounds like B-carotene and Chlorophyll-a.
dibilo
Hi all, I have just done a liquid separation of B-carotene and Chlorophyll-a and put the 2 samples through a UV spectrometer.
The result that I get from the meter for B-carotene is 448nm for 1st peak and 475.1nm for 2nd peak.
For Chlorophyll-a my peaks are at 417.9nm and 666.1nm.
But I have a few questions here. Why are there 2 peaks for each of them? Is it normal? Is it due to the presence of impurities? Is it due to me not choosing the appropriate blank for the UV spectrometery test?
For the case of B-carotene, the 2 peaks are so close together which means they have really poor resolution. Is it normal?
Thanks in advance for anyone who can offer me a little guidance.
Regards,
dibilo.
B-Carotene and Chlorophyll-a are conjugated organic molecules, the excitation spacing (pi to pi) for B-Carotene is closer together in the visible region since it's more conjugated. A lot of this stuff can be explained quantitatively by the particle in a box model.
You can ascertain the color of the solution by employing color methods, the two peaks represent the wavelengths that the molecule absorbs, familiarize yourself with some of the basic principles of "color theory" to understand why B-Carotene appears orange, for instance.
11K
