Simple car acceleration formula?
The discussion revolves around the theoretical acceleration and top speed of a car based on parameters such as power, mass, and drag. Participants explore the complexities involved in calculating these metrics, including real-world factors that influence performance.
  • Some participants suggest that a simple formula for acceleration and top speed exists, but acknowledge the complexities involved in real-world scenarios.
  • One participant mentions that drag racers use devices like G-teck for instant performance metrics, while others express skepticism about their accuracy.
  • Another participant emphasizes the importance of knowing average power applied over time and the impact of drivetrain losses on performance calculations.
  • There is a discussion about how tire traction and weight affect acceleration, noting that downforce increases with speed, complicating the relationship between power and acceleration.
  • A participant provides a mathematical approach to calculating top speed, indicating that it is achieved when drag equals driving force, and presents a formula relating power and speed.
Participants generally agree that acceleration and top speed calculations are complex and influenced by multiple factors. However, there is no consensus on the effectiveness of specific formulas or methods, and differing opinions on the use of performance measurement tools like G-teck are evident.
Limitations include the dependence on various assumptions such as constant power output, the influence of drivetrain losses, and the variability of tire traction under different conditions. The discussion highlights the non-linear nature of acceleration in drag racing.
jpsa
is there a simple formula to get the theoretical acceleration and top speed of a car given power, mass and drag?
MAYBE
but in the real world drag racers
use a box called a G-teck to get instant answers
gear ratio and tyre traction are also big factors as is driver skill
F = ma.
And ray, the Gtech sucks.
- Warren
You would also need to know the average power applied as a function of time (unless you have a CVT) and drivetrain losses.
The tire/traction point is an interesting one as well, the typical understanding of analyzing 1/4 mile tests is to use the MPH as more an indication of power:weight and the 60ft and ET to determine how large a component the launch played in the run down the track.
There were some approimation formulas published in Hot Rod magazine a few years back, maybe someone has posted something similar online.
Cliff
Cliff
Good point. A car's power is not constant, if you have ever seen dynamometer results, the power generally increases as RPM increases, except with turbocharged engines which are more dependent on the RPM of the turbo itself. Anyway, in addition to that, you can only apply as much power as your tires have traction, which increases as weight/downforce increases. As we know, downforce increases as the car's speed increases, and more weight is transferred to the rear as the car accelerates faster (or to the front as it slows its acceleration such as during shifting). Speaking of shifting, you must also add the time it takes to shift, which is different for every driver. So as you can see, acceleration is far from linear, which is why drag racing is a sport and not a study. ;) Don't let me mislead you though, if you think drag racing is complicated, try drifting!
Acceleration is complicated, as it depends upon speed, drag and power and weight. Top speed is easy, as it depends only on drag and power. Top speed is achieved when drag equals driving force. But driving force is power over speed and drag is a constant times speed squared. Therefore,
[tex]{P\over v_\infty}= \mbox{constant }\times v_\infty^2[/tex]
or
[tex]v_\infty=\mbox{constant }\times P^{1/3}[/tex]
For example, for a small aerodynamic car, top speed in mph is 25 times the cube root of the horsepower.
  • · Replies 17 ·
  • · Replies 95 ·
  • · Replies 55 ·
  • · Replies 36 ·
