Torque Required to Stop a Rotating Grinding Wheel
  • Thread starter Thread starter needhelp83
    Torque
The discussion revolves around calculating the angular momentum and the torque required to stop a rotating grinding wheel. The problem involves a uniform cylindrical grinding wheel with specific mass and radius, rotating at a given speed.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the calculation of angular momentum and the application of torque concepts. Questions arise regarding the determination of torque needed to stop the wheel within a specified time frame. Some participants suggest using angular deceleration and the relationship between torque and angular acceleration.
Participants have made progress in calculating angular momentum and have proposed methods for determining torque. There is an ongoing exploration of different approaches to find the average torque required, with some calculations presented but no consensus reached on the final method.
Participants are working under the constraints of a homework problem, which may limit the information available and the methods they can use. The discussion includes checking assumptions related to angular deceleration and the relationship between torque and angular momentum.
needhelp83
Problem 2) What is the angular momentum of a 2.8 kg uniform cylindrical grinding wheel of radius 18 cm when rotating at 1500 rpm?
b) How much torque is required to stop it in 7.0 s?
1500 rpm * 2pi rad = 9424.78 rad/m
(9424.78 rad/m) /60 s = 157.08 rad/s
I = 1/2mr2
I = 1/2(2.8 kg)(.18 m)2 = 0.04536 kgm2
L = Iw = (0.04536 kgm2)(157.08 rad/s) = 7.13 kgm2/s
I have determined the angular momentum, but I am unsure of how to determine the torque required to stop it in 7 s
How do you determine this with the torque formula and time involved? Any help?
The definition of torque is
[tex]\mathbf\tau = \frac{d\mathbf{\mathrm L}}{dt}[/tex]
If you want to change the angular momentum from your value to 0, then the average torque over 7 s most then be?
t=(7.13 kgm^2/s)/7.0 s=1.02 kgm^2
Better?
hmm...well you know the initial angular velocity ''157.08 rad/s''. I would say you need to calculate the angular deceleration of the spinning wheel from 157.08 r/s to 0 r/s in 7 secs using W(final)=W(initial)+a^t. I make the angular deceleration 22.44 rad s-2.
Then using the formula T=I x a...cha ching !
w=w0+at
0=157.08+a(7)
-157.08=7a
a=-22.44 rad/s^2 since stopping
T=Ia
T=0.04536 kgm^2*-22.44
T=-1.02 m*N
  • · Replies 35 ·
  • · Replies 19 ·
14K
