Can Any Integral Weight Up to 121 Ounces Be Measured with Five Specific Weights?
  • Context: Graduate
  • Thread starter Thread starter nocheesie
    Balance
The discussion revolves around the problem of determining whether any integral weight up to 121 ounces can be measured using five specific weights of 1, 3, 9, 27, and 81 ounces on a two-pan balance. Participants explore the generalization of this result and the implications of using weights that are powers of different bases.
  • One participant notes that the weights can measure every integer from 1 to 121 ounces, highlighting that the sum of the weights equals 121 ounces.
  • Another participant suggests that generalizing the result involves considering other sets of weights, such as powers of 2 or powers of 4, and questions how these would function in the context of the problem.
  • A different viewpoint introduces the idea that using weights in a base-n system allows for weighing amounts up to n^(r+1) with n-1 weights, but questions how this applies with only one weight of each unit.
  • One participant explains how using the two-pan balance allows for the representation of weights in base 3, where the absence of a weight for 2 ounces can be compensated by placing a weight on the opposite side of the scale.
  • Another participant elaborates on the limitations of using powers of 4, noting that certain weights cannot be represented, such as 2 ounces, due to the available weights.
  • There is a discussion about the maximum weight that can be measured, with references to the inability to exceed 121 ounces due to the constraints of the weights available.
Participants express various viewpoints on the generalization of the problem and the implications of using different bases for weights. There is no consensus on a single method or conclusion, and multiple competing views remain regarding the generalization and limitations of the weights.
Some assumptions about the use of weights and the mechanics of the two-pan balance are not fully explored, and the discussion includes unresolved mathematical steps related to the generalization of the problem.
nocheesie
This is a problem from my abstract algebra book written by Ted Shifrin:
A druggist has the five weights of 1, 3, 9, 27, and 81 ounces, and a two-pan balance. Show that he can weigh any integral amount up to and including 121 ounces. How can you generalize this result?
While I see how it's possible to obtain lots of different weights with these 5, I have absolutely no idea how I can generalize my result. Does anyone know the answer to this problem? Thanks a lot in advance.
The first step in generalizing a statement is to be sure you understand what is said. It is not just the case that " it's possible to obtain lots of different weights". The point is that it is possible to obtain every integer from 1 to 121 oz. Did you notice that 1+ 3+ 9+ 27+ 81= 121? Did you notice that 1, 3, 9, 27, and 81 are all powers of 3? How would you use those weights to weigh something that weighed 2 oz? 4 oz?
The second step is trying other special cases. What could you weigh if you had weights of 1, 2, 4, 8, 16 (powers of 2)? What about 1, 4, 16, 64, 256 (powers of 4)? Powers of 5?
there are many generalizations for this,
key thing: 2 is 3-1.
usually you can weigh any amount up to n^(r+1) using n-1 weights each weighing 1,n,..n^r units. this is like taking the expansion of a number in base n.
here we would require two weights of each unit, apparently , but we only have one, so how does it work? cos where as to weigh two units would usually by 1+1, we can use 3-1, the minus meaning put it on the other side to the 3.
if the base were powers of 4 you couldn't weigh 2 units. you can do 1, and 3=4-1... but not two.
If we have two weights we need only to use one side of the scale. In base 2, we just write 1 or 0. So the max for 5 weights, 1, 2, 4, 8, 16 in base two will be written 11111, which is equal to 2^5-1 =31 in its extent. The base 4 as noted will not work because we can not write 2, since we have 1, 4, 16...
In base three, everything is written as 0,1,2. But we have no two in our weights, but we can use both sides of the scale. Example:
Take 210 base 3 = 2x9+1x3 = 21 base 10. We do not have the 2, but we can replace it with -1 (putting it on the other side of the scale) and "bump up" the digits like we would in base 10, getting not 210 base 3, but 1(-1)10 base 3 = 27-9+3 =21 base 10.
Now, 10211 can be bumbed up to 11(-1)11. But the number 10211 = 103 base 10 is less than 11111=121 base 10, and this situation will always happen since 02 =2 is less than 11 =4 base 10.
The problem is limited by the fact that can not "bumb up" on weight 81 because that is the highest of the weights, and so after 11111 base 3, we can go no higher because a 2 anywhere would require a 6th weight. So the max is 11111 = (3^5-1)/(3-1) = 121 base 3.
