Finding velocity taking the pulley into consideration
  • Thread starter Thread starter vu10758
    Pulley Velocity
The problem involves two blocks connected by a pulley system, with specific parameters including masses, friction coefficients, and the moment of inertia of the pulley. The goal is to find the speed of the masses after they have moved a certain distance, taking into account the effects of friction and the pulley.
  • Mixed
  • Participants discuss kinematic relationships and equations related to constant acceleration. There are attempts to derive time and velocity from acceleration, with some questioning the correctness of the acceleration calculation. Free body diagrams are analyzed, and participants express uncertainty about their accuracy and the relationships between forces acting on the blocks and the pulley.
There is ongoing exploration of the relationships between forces and torques in the system. Some participants have provided guidance on checking calculations and considering the signs of tensions in the pulley. Multiple interpretations of the free body diagrams and the resulting equations are being discussed, indicating a productive exchange of ideas.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is a focus on ensuring that all forces and torques are accounted for correctly in the analysis.
vu10758
The picture for this problem is at http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=128765607&imageID=1423590496
It is problem number 9. I also have my work so far there.
Two blocks are connected as shown. Friction between M1 and the horizontal surface is characterized by mu_k = .25 and mu_s=.5. The pulley has I = .16kgm^2 about its center and a radius of .2m. Find the speed of the masses after they moved 2m. Assume that M1 is still on the horizontal surafece after those 2m so that the friction force will act over the entire 2m. Use M1 = 2kg and M2 = 6kg.
I did my work and ended up with accerleration being 3.26 however, I can't get the velocity. I don't know how to get the velocity, and I am not sure if I am overlooking some kinds of relationship between the variables.
There's a simple kinematic formula that relates velocity and distance for a constant acceleration. You can either look it up or derive it for yourself. (Consider the definitions of acceleration and average speed.)
I know that d = (1/2)at^2 since v_o and x_o are both zero.
2 = (1/2) at^2
4 = at^2
4/3.26 = t^2
t = 1.107
v = v_o + at
v = 3.26(1.10)
v = 3.61
However, the correct answer should be 4.24. What am I doing wrong?
Nothing wrong with your kinematics. So better check that you calculated the acceleration correctly.
That's the problem: Your calculation of acceleration is incorrect.
Are my free body diagrams correct? For M1, I have normal force pointing up, Tension 1 point right, static friction pointing left, and gravity pointing down. For M2, I have tension2 pointing up and gravity pointing down. For the pulley, I have Tension 1 pointing left and Tension 2 pointing down. I think that I might have made some mistakes here.
M1
x) T1- f = M1*a
y) N - M1*g = 0
M2
T2-M2*g = -M2*a
Pulley
-T1*R -T2*R = I (-alpha)
T1*R + T2*R = I*(alpha)
So I have
R(T1+T2) = I (a/R)
R^2(T1+T2) = Ia
Ia = R^2(M1*a + mu_s*M1*g + M2*g - M2*a)
Ia -R^2*M1*a + R^2*M2*a = R^2*M2*g + R^2 * mu_s*M1*g
a = [R^2*M2*g + R^2*mu_s*M1*g]/(I+R^2*M2 -R^2*M1)
I plugged in all of my values from the problem and got 8.575 for a, which is wrong when I try to find velocity.
vu10758 said:
M1
x) T1- f = M1*a
y) N - M1*g = 0
M2
T2-M2*g = -M2*a
Good.
Pulley
Realize that T1 and T2 exert opposite torques on the pulley and thus must have opposite signs.
Since T1 is trying to cause the pulley to rotate counterclockwise, while T2 is causing it to rotate clockwise, would it work if I have
T1*R-T2*R = I (-alpha)
That looks good to me.
17K
