Is My Calculation for Cylinder and Piston Height Correct?
  • Thread starter Thread starter S_fabris
The discussion revolves around calculating the height of a piston in a vertical cylinder containing an ideal gas. The problem involves concepts from thermodynamics and fluid mechanics, specifically relating to pressure, volume, and the behavior of gases under equilibrium conditions.
  • The original poster attempts to calculate the height of the piston using pressure derived from the weight of the piston and the area of the cylinder. They express concern over the high values obtained for height and seek confirmation of their calculations.
  • Some participants question the accuracy of the pressure calculation and suggest considering atmospheric pressure in the overall pressure exerted on the gas.
  • Others explore the implications of using the ideal gas law and the relationship between pressure, volume, and temperature.
Participants have provided guidance on recalculating pressure and have pointed out the importance of including atmospheric pressure in the calculations. There is an ongoing exploration of the correct approach to the problem, with varying interpretations of the results being discussed.
There is mention of homework service discrepancies, indicating that the original poster is working under specific constraints or guidelines that may affect the calculations. The discussion reflects uncertainty regarding the application of formulas and assumptions about the system being analyzed.
S_fabris
I think I might have this one right but my answer seems kinda high...can somebody help me out...just to confirm
A vertical cylinder of cross-sectional area 0.045m2 is fitted with a tight-fitting, frictionless piston of mass 6.5kg. The acceleration of gravity is 9.8 m/s2, andthe universal gas constant is 8.31451 J/Kmol.
If there are 4.4mol of an ideal gas in the cylinder at 412 K, determine the height h at which the position is in equilibrium under its own weight (in units of m).
The work I have so far is the following:
Pressure=f x area=(6.5kgx9.81)x(0.045m2)
=2.869N/m2
using PV=nRT I isolated my Volume
V = (4.4mol x 8.3145 x 412K) / 2.869N/m2
= 5253.58 m3
Using this volume inside the cylinder I want to find the height:
h = volume/area
= 5253.58m3 / 0.045m2
= 116 746.22m (this seems kind of high for a height, no?)
I also tried this
Area of cylinder = 2 x pie x r2
isolated my radius then plugged that into V = pie x r2 x h
the height I calculated was 334688.55m (once again pretty high)
I'm assuming my first calculation h= volume/area is a more reliable answer but I just need some assurance as to my answer...it seems pretty high for a cylinder/piston
Thanks
Sergio
Good of you to be suspicious of this answer. Check your pressure calculation.
Ah yes Pressure = Force DEVIDED by area...
...long day :P
Thank you OlderDan
Sergio
I tried doing the same calculations using the corrected pressure equation and came to the answer of 236.38meters (using height = volume / area) and this isn't the correct answer on the homework service...again is it a formula problem i am having? (i tried the calcs a few times over to make sure)
Anybody? thanks...:)
You are ignoring atmospheric pressure. Total pressure on the gas is atmospheric pressure plus the piston pressure.
You can easily see that your volume cannot be right. 4.4 moles at STP would be 4.4 x 22.4 = 98.6 l = .0986 m^3. This is just a little more than atmospheric pressure (about 1.5 kPa above atmospheric pressure which is about 101 kPa).
I get a little more than 3 metres.
AM
Perfect, ur right i totally forgot about the atmospheric pressure exerted on the piston...I added 1.013x10^5N/m2 to my calculated pressure ...after all the calcs i got 3.26m which makes MUCH more sense and it is correct :D
thank you all for your patience...
Sergio
12K
