Investigating Midair Stalling of an Aircraft
  • Thread starter Thread starter Raghu K Mohandas
    Aircraft
The discussion centers around the phenomenon of midair stalling of an aircraft, exploring its causes and implications. Participants are seeking to clarify the concept and differentiate it from other types of stalling, particularly in relation to aerodynamics and aircraft operation.
  • One participant expresses confusion about the reasons behind midair stalling and requests validated explanations from experts in aerodynamics.
  • Another participant clarifies that a stall in aviation is distinct from a stall in automotive contexts, emphasizing that it relates to airflow around the wings and lift rather than engine function.
  • A participant questions the initial premise of the discussion, asking for clarification on what is meant by "mid-air stalling" and suggesting that the original poster define the specific situation they are investigating.
  • There is a reference to a Wikipedia article on stalls in flight, which one participant acknowledges as a good resource despite their usual skepticism towards Wikipedia.
Participants do not appear to reach a consensus on the understanding of midair stalling, with some clarifying its definition while others question the initial assumptions. The discussion remains unresolved regarding the specific causes and implications of midair stalling.
There are indications of missing definitions and assumptions regarding what constitutes a stall in the context of aviation versus other contexts. The discussion also reflects varying levels of familiarity with the topic among participants.
Individuals interested in aerodynamics, aviation safety, and the technical aspects of flight dynamics may find this discussion relevant.
Raghu K Mohandas
Hey guys,
Even iam trying to find out the reason behind the midair stalling of an aircraft if it really exists. The truth is iam not able to get the correct and validated reason for the query.
So i request you guys once more to take up this issue and answer this query which is really bugging since a long time.
Will be appreciated if an guy from aerodynamics can answer this question.
Hoping for an validated reason at the earliest.
Regards
raghu
Hope this is okay -- I moved this from a homework forum to this Aerospace Engineering forum. Sounds more like a general conceptual question, and the OP will get the best help here.
reply berkeman
Hey , dint get you are you trying to answer the question ? pls be clear...
can post it if you get the answer.
Raghu
No sir, I wasn't trying to answer the question. But I was trying to help get you an answer to your question. You posted your question in the homework forums, which is generally a good idea. But your question sounded general enough that I thought it best to move it to the specialized Aeronautical forum, where it might get more exposure from the wide varitey of experts. Please give it overnight to get some views (it's almost midnight now on the US west coast), and hopefully you'll get some responses in the next day or so.
Welcome to the PF, by the way. It's a very valuable place, and very helpful.
Raghu, I hope that you are not making the common mistake of thinking that a stall in an aircraft is the same as a stall in a car. It has nothing to do with engine function. In an aeroplane, a stall occurs when the airflow around the wings is no longer sufficient to provide lift. This is most often encountered when the angle of attack of the wing exceeds a particular level at a given forward airspeed, although a sudden severe drop in ambient air pressure could have the same result.
Mid-air stalling versus what, on the ground stalling? (sorry for being sarcastic).
Stalling definitely happens. What makes you think it doesn't? Since Danger already gave you the Reader's Digest version, here's some more information to get you started: http://en.wikipedia.org/wiki/Stall_(flight )
First, let's start with what YOU are calling a "stall." Please define the particular situation you are trying to look into.
While I normally don't trust Wiki much, that's a really good article. Thanks, Fred.
Puts me in mind of what the old Sopwith pilots used to say: "Pull the stick back to go up; pull it back some more to come down." :biggrin:
  • · Replies 56 ·
17K
  • · Replies 22 ·
