Integragtion Problem with Substitution
  • Context: Undergrad
  • Thread starter Thread starter Claire84
    Substitution
The discussion revolves around solving an integration problem involving the integral of sqrt(x) divided by (1 + x^2) using the substitution x = tan^2(t). Participants explore various substitution methods, transformations, and integration techniques, expressing confusion and seeking clarification on the steps involved.
  • One participant describes their struggle with the integration problem and the complexity arising from the substitution x = tan^2(t).
  • Another participant suggests that the integral of 1/sin^2(x) is -cot(x), indicating a potential complexity in the solution.
  • Some participants propose that the expected answer is 2(sqrt(x)) - 2tan^-1(sqrt(x)), while others question the validity of this result.
  • There is a suggestion to rewrite tan^2(x) in terms of trigonometric identities to simplify the integration process.
  • Multiple participants express confusion over the steps leading to the integral of 1 over -sin^2(t) and how to revert back to x after integration.
  • One participant mentions a potential misprint in the problem statement, suggesting that using x = tan(t) might be more appropriate.
  • Discussions include various transformations and substitutions, with some participants suggesting different approaches to tackle the integral.
  • There is mention of a table of integrals being referenced to find solutions, indicating reliance on external resources for clarification.
  • Participants express uncertainty about the correctness of their steps and the final form of the integral, leading to further questions about the expected answer.
Participants do not reach a consensus on the correct approach or final answer. Multiple competing views and methods are presented, with ongoing confusion and uncertainty about the integration process.
Some participants note that the integration problem may involve complex transformations and that certain assumptions or misprints in the problem statement could affect the approach taken. There is also mention of the need to clarify the expected form of the answer, particularly regarding the presence of square roots and the treatment of x in the final expression.
Claire84
At the moment I'm trying to solve this integration problem and it's not working out asd neatly as any other substituion problem I've tried before.
We have to integrate sqrtx divided by (1 + x^2) using the substitution x= tan^2t (as in tan squared t). So when we have dx/dt so you get 2tantsec^2t? I've tried using that but it all gets really muddled and complex. At the moment I'm down to finding the integral of 8 divided by -sin^2t but I'm not sue where to go from there. I've tried using substituions from this point on using the dpuble angle formulae but it's all going a bit pear-shaped. Any help would be much appreciated- thanks in advance!
The integral of 1/sin^2(x) is -cot(x). Seems like the answer would be more complex...
The answer we're supposed to get to is 2(sqrtx) - 2tan^-1(sqrtx)
That's the integral of sqrt(x) / (x + 1) (notice the lack of a squared term in the denominator), which is "somewhat" easier than sqrt(x) / (x^2 + 1) ;)
We wish to integrate sqrt(x) / (1 + x) dx.
Let x = tan^2(t), which gives dx = 2tan(t)sec^2(t) dt.
The integral turns into sqrt(tan^2(t)) / (1 + tan^2(t)) * 2tan(t)sec^2(t) dt. The numerator is equal to sec^2(t) (standard identity). We can simplify it to:
tan(t)/sec^2(t) * 2tan(t)sec^2(t) dt =
tan(t)2tan(t) dt =
2tan^2(t) dt
Hopefully you can handle the rest.
Really? Eeek what's wrong with this sheet then? It tells us to use the substitution x=tan^2(x) so would we not then need this for the one you've suggested? V.confusing.
Added more info to the last post :wink:
Btw, try inputting Sqrt[x] / (x^2 + 1) at http://integrals.wolfram.com/ , and see what you get... Not the kind of thing you'd want work out for yourself on paper
LOL, while you were typing that I was off tryingit myself and I've got down to the 2tan^2(t) bit! After that is there an integral you can use or do you have to change it to sin^2(x) over cos^2(x) and then use the double angle formulae? It just looks messy everytime I work with it? God, I should really remember to bring my brain home with me from uni!
Personally, I'd rewrite it as tan^2(x) = (1 - cos^2(x)) / cos^2(x) = 1/cos^2(x) - 1 and work from there.
looks like a simple misprint, just use x=tan(t)
for questions like this, try and fiddle cos^2 + sin^2 =1 so you get something that looks like what you want
Hm okay, so if we had 1 over cos^2x - 1 would you then have to change that to -sin^x? You gave the integral of this earlier, well the integral of 1 over sin^2x which was -cotx, but how did you work that out? I'm generally fine with differentiating but integration is really confusing me, esp. when you have 1 over a trigonometric function.
Looked it up :wink: I'm not aware of any way to "construct" such trigonometric integrals, other than simply checking the derivatives of the standard trig. functions (i.e sec(x), sec^2(x), csc(x), etc) and seeing if something fits.
Hm but how do we get the correct answer then if we have the integral of 1 over -sin^2x?
Okay if we end up with the integral being -cot(t) then what do we do? How do we get x back into it from what we made x equal to?
I end up with 1/x. Odd.
ignore me, didn't see the sqrt x in there
int 1/sin^2(t) is cot(t) give or take a minus sign.
x=tan^2t
so tan(t)=sqrt(x)
and tan is 1 over cot
so cot (t) is 1/sqrt(x)
Okay, I just need to know how you get from the integral of 1 over -sin^t to 2sqrtx - 2tan^-1(sqrtx). It just doesn't seem to work.
Looks like there's some confusion here. I said that tan^2(x) = 1/cos^2(x) - 1. The -1 is /not/ in the nominator. I meant (1/cos^2(x)) - 1, or sec^2(x) - 1. The integral of this is tan(x) - x (found a table of integrals here: http://www.math2.org/math/integrals/tableof.htm), so the integral of 2tan^2(t) dt (please excuse the sudden change of variables) is 2tan(t) - 2t.
Since we let x = tan^2(t), get that that sqrt(x) = tan(t), or t = atan(sqrt(x)).
Which gives 2tan(t) - 2t = 2tan(atan(sqrt(x))) - 2atan(sqrt(x)) = 2sqrt(x) - 2atan(sqrt(x)).
Plus a constant. ;)
Plus a constant. ;)
dunno if I'm helping or not, but, muzza, you've inconsistently muddled up t's and x's throughout these posts. perhaps claire starting again from the beginning would help along with her posting all her working out up to the point she gets stuck.
Yeah.
Okay, I'll go scan in my working out because it's easier to see on paper!
Okay, couldn't get it small enough. Really not good with computers. Here's what I have.
I've got that dx=2tantsec^2(t)dt
so overall, the integral from before with the substituion x=tan^2(t) is
tanx divided by a+tan^2(t), and this whole thing is multiplied by the new value of dx with the dts in it that I mentioned above. I've got that all this cancels down to the form where we have the integral of 2tan^2(t), and then you could take the 2 outside of the integral sign but I'm not too sure what to do next.
ok, we agree (up to multiplying by a minus sign at least,) that you want to integate tan squared
tan squared is sin^2/cos^2
ie
(1-cos^2)/cos^2 = -1 + sec^2
so integrating that wrt t (forget the factor of two out the front) gives us -t + cot(t)
recall tan^2(t) = x so tan(t) = sqrt(x)
t = tan^(-1)(sqrt(x))
cot(t) = 1/sqrt(x)
so the integral (again forgetting that two)
is -1/sqrt(x) + tan(-1)(sqrt(x))
put the two in (I think it's minus two cos diff tan gives -sec^2, not sec^2)
gets you close to what you want. not sure about the 1/sqrt(x) - can you check the answer sheet, does it say x to the half or x to the minus half?
The exact answer that is given is 2sqrtx -2tan^-1(sqrtx). So both square roots are positive.
Oh and I never knew that integrating sec^2(t) gave you cot(t). Is that one of the integrals you're supposed to remember? Is it easy enough to work out?
As in x to the half as opposed to the minus half.
So there's definitely no way that the x on the bottom line could be x^2 then? Just so I can let people know at uni tomorrow cos I know a lot of them were getting a bit agitated at this question...
well, it could be, but that would be a nasty integral to solve, seriously nasty, and it is so close to the one with x not x^2 on the bottom... mistakes happen on homework sheets.
The lecturer today confirmed today that is was x on the bottom line as opposed to the x squared. But still don't have correct answer. Major brain frazzlement!
Have got the right answer, I think! It's actually from one of the previous posts here but I've got that the integral of sec^x is tanx as opposed to cotx. Hope that's right. If not, don't spoil my excitment at actually having possibly got something right.
  • · Replies 21 ·
  • · Replies 19 ·
